imx vpu wrapper VpuEncOpenParam
1,880 次查看
TDKamil
in VpuEncOpenParam structure there are new fields:
int nFullRange;
int nColorConversionType;
int nStreamSliceCount;
However I cannot find any information about how to use this.
Is there any documentation available?
1,849 次查看
TDKamil
Thank you. Whats the difference between
vpu_wrapper_hantro_VCencoder.c and
vpu_wrapper_hantro_encoder.c
Which one should be used for imx8m mini application?
1,859 次查看
TDKamil
My kernel is 5.4.24 (from SOMLabs, NXP partner) and I still cannot find those fields  (nFullRange, nColorConversionType, nStreamSliceCount) in any documentation.
However when i migrated from 4.14.98 (8mminilpd4-evk) to the 5.4.24 (VisionSOM-8Mmini) with same settings of VPU wrapper (recompiled with proper SDK) the output from video encoder seems broken. It was working perfectly on old kernel. I still can grab video but it seems like there are some changes with VPU wrapper or h264 encoder.
1,868 次查看
Bio_TICFSL
Hello TDKamil,
You can find all the VPU parameter in the iMX_VPU application Programing document in your yocto documents folder. You can download the documents from:
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
