iMX95: Compilation error with bitbake.
danielsan-77
I want to compile from the source code, but I get errors when compiling it for the iMx95. I am working with a computer with Ubuntu 18.04. To do this I follow the steps of I have followed the steps of https://dev.variscite.com/dart-mx95/mx95-yocto-walnascar-6.12.49_2.2.0-v1.0/yocto-build-release/
Specifically, when launching the "bitbake fsl-image-gui-chromium" I get this error:
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Fetcher failure for URL: 'https://www.yoctoproject.org/connectivity.html'. URL doesn't work.
Please ensure your host's network is configured correctly.
Please ensure CONNECTIVITY_CHECK_URIS is correct and specified URIs are available.
If your ISP or network is blocking the above URL,
try with another domain name, for example by setting:
CONNECTIVITY_CHECK_URIS = "https://www.example.com/" You could also set BB_NO_NETWORK = "1" to disable network
access if all required sources are on local disk.
Summary: There was 1 ERROR message, returning a non-zero exit code.
I have also tried other previous versions, but the same thing happens.
The same error occurs if I launch other bitbakes.
All the best,
Daniel.
JorgeCas
I suggest you check directly with Variscite since our BSP is built and requirements are different.
Please check if this is a known issue in the recipe or if you have some kind of firewall issue since you have fetch errors.
Best regards.
danielsan-77
Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-2346316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX95%3A%20Compilation%20error%20with%20bitbake.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20want%20to%20compile%20from%20the%20source%20code%2C%20but%20I%20get%20errors%20when%20compiling%20it%20for%20the%20iMx95.%20I%20am%20working%20with%20a%20computer%20with%20Ubuntu%2018.04.%20To%20do%20this%20I%20follow%20the%20steps%20of%20I%20have%20followed%20the%20steps%20of%20%3CA%20href%3D%22https%3A%2F%2Fdev.variscite.com%2Fdart-mx95%2Fmx95-yocto-walnascar-6.12.49_2.2.0-v1.0%2Fyocto-build-release%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdev.variscite.com%2Fdart-mx95%2Fmx95-yocto-walnascar-6.12.49_2.2.0-v1.0%2Fyocto-build-release%2F%3C%2FA%3E%3C%2FP%3E%3CP%3ESpecifically%2C%20when%20launching%20the%20%22bitbake%20fsl-image-gui-chromium%22%20I%20get%20this%20error%3A%3C%2FP%3E%3CP%3EERROR%3A%20OE-core's%20config%20sanity%20checker%20detected%20a%20potential%20misconfiguration.%3CBR%20%2F%3EEither%20fix%20the%20cause%20of%20this%20error%20or%20at%20your%20own%20risk%20disable%20the%20checker%20(see%20sanity.conf).%3CBR%20%2F%3EFollowing%20is%20the%20list%20of%20potential%20problems%20%2F%20advisories%3A%3C%2FP%3E%3CP%3EFetcher%20failure%20for%20URL%3A%20'%3CA%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fconnectivity.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2Fconnectivity.html%3C%2FA%3E'.%20URL%20doesn't%20work.%3CBR%20%2F%3EPlease%20ensure%20your%20host's%20network%20is%20configured%20correctly.%3CBR%20%2F%3EPlease%20ensure%20CONNECTIVITY_CHECK_URIS%20is%20correct%20and%20specified%20URIs%20are%20available.%3CBR%20%2F%3EIf%20your%20ISP%20or%20network%20is%20blocking%20the%20above%20URL%2C%3CBR%20%2F%3Etry%20with%20another%20domain%20name%2C%20for%20example%20by%20setting%3A%3CBR%20%2F%3ECONNECTIVITY_CHECK_URIS%20%3D%20%22%3CA%20href%3D%22https%3A%2F%2Fwww.example.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.example.com%2F%3C%2FA%3E%22%20You%20could%20also%20set%20BB_NO_NETWORK%20%3D%20%221%22%20to%20disable%20network%3CBR%20%2F%3Eaccess%20if%20all%20required%20sources%20are%20on%20local%20disk.%3CBR%20%2F%3ESummary%3A%20There%20was%201%20ERROR%20message%2C%20returning%20a%20non-zero%20exit%20code.%3C%2FP%3E%3CP%3EI%20have%20also%20tried%20other%20previous%20versions%2C%20but%20the%20same%20thing%20happens.%3C%2FP%3E%3CP%3EThe%20same%20error%20occurs%20if%20I%20launch%20other%20bitbakes.%3C%2FP%3E%3CP%3EAll%20the%20best%2C%3CBR%20%2F%3EDaniel.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX95%3A%20Compilation%20error%20with%20bitbake.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX95%3A%20Compilation%20error%20with%20bitbake.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EI%20suggest%20you%20check%20directly%20with%20Variscite%20since%20our%20BSP%20is%20built%26nbsp%3Band%20requirements%20are%20different.%3C%2FP%3E%0A%3CP%3EPlease%20check%20if%20this%20is%20a%20known%20issue%20in%20the%20recipe%20or%20if%20you%20have%20some%20kind%20of%20firewall%20issue%20since%20you%20have%20fetch%20errors.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
