iMX95: Compilation error with bitbake.
989 次查看
danielsan-77
I want to compile from the source code, but I get errors when compiling it for the iMx95. I am working with a computer with Ubuntu 18.04. To do this I follow the steps of I have followed the steps of https://dev.variscite.com/dart-mx95/mx95-yocto-walnascar-6.12.49_2.2.0-v1.0/yocto-build-release/
Specifically, when launching the "bitbake fsl-image-gui-chromium" I get this error:
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Fetcher failure for URL: 'https://www.yoctoproject.org/connectivity.html'. URL doesn't work.
Please ensure your host's network is configured correctly.
Please ensure CONNECTIVITY_CHECK_URIS is correct and specified URIs are available.
If your ISP or network is blocking the above URL,
try with another domain name, for example by setting:
CONNECTIVITY_CHECK_URIS = "https://www.example.com/" You could also set BB_NO_NETWORK = "1" to disable network
access if all required sources are on local disk.
Summary: There was 1 ERROR message, returning a non-zero exit code.
I have also tried other previous versions, but the same thing happens.
The same error occurs if I launch other bitbakes.
All the best,
Daniel.
965 次查看
JorgeCas
I suggest you check directly with Variscite since our BSP is built and requirements are different.
Please check if this is a known issue in the recipe or if you have some kind of firewall issue since you have fetch errors.
Best regards.
945 次查看
danielsan-77
Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-2346316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX95%EF%BC%9Abitbake%20%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E6%A0%B9%E6%8D%AE%E6%BA%90%E4%BB%A3%E7%A0%81%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%EF%BC%8C%E4%BD%86%E5%9C%A8%E4%B8%BA%20iMx95%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E7%9A%84%E7%94%B5%E8%84%91%E8%A3%85%E6%9C%89%20Ubuntu%2018.04%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E9%81%B5%E5%BE%AA%E4%BA%86%3CA%20href%3D%22https%3A%2F%2Fdev.variscite.com%2Fdart-mx95%2Fmx95-yocto-walnascar-6.12.49_2.2.0-v1.0%2Fyocto-build-release%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdev.variscite.com%2Fdart-mx95%2Fmx95-yocto-walnascar-6.12.49_2.2.0-v1.0%2Fyocto-build-release%2F%3C%2FA%3E%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%BD%93%E5%90%AF%E5%8A%A8%22bitbake%20fsl-image-gui-chromium%22%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9AOE-core%20%E7%9A%84%E9%85%8D%E7%BD%AE%E6%AD%A3%E7%A1%AE%E6%80%A7%E6%A3%80%E6%9F%A5%E7%A8%8B%E5%BA%8F%E6%A3%80%E6%B5%8B%E5%88%B0%E4%B8%80%E4%B8%AA%E6%BD%9C%E5%9C%A8%E7%9A%84%E9%94%99%E8%AF%AF%E9%85%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%E8%A6%81%E4%B9%88%E4%BF%AE%E5%A4%8D%E5%AF%BC%E8%87%B4%E8%AF%A5%E9%94%99%E8%AF%AF%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%8C%E8%A6%81%E4%B9%88%E8%87%AA%E8%A1%8C%E6%89%BF%E6%8B%85%E9%A3%8E%E9%99%A9%E7%A6%81%E7%94%A8%E6%A3%80%E6%9F%A5%E5%99%A8%EF%BC%88%E5%8F%82%E8%A7%81%20sanity.conf%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%BD%9C%E5%9C%A8%E9%97%AE%E9%A2%98%2F%E5%BB%BA%E8%AE%AE%E6%B8%85%E5%8D%95%EF%BC%9A%3C%2FP%3E%3CP%3EURL%20%E7%9A%84%20Fetcher%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fconnectivity.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2Fconnectivity.html'%3C%2FA%3E.URL%20%E6%97%A0%E6%95%88%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E7%A1%AE%E4%BF%9D%E4%B8%BB%E6%9C%BA%E7%BD%91%E7%BB%9C%E9%85%8D%E7%BD%AE%E6%AD%A3%E7%A1%AE%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E7%A1%AE%E4%BF%9D%20CONNECTIVITY_CHECK_URIS%20%E6%AD%A3%E7%A1%AE%E4%B8%94%E6%8C%87%E5%AE%9A%E7%9A%84%20URI%20%E5%8F%AF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E7%9A%84%E4%BA%92%E8%81%94%E7%BD%91%E6%9C%8D%E5%8A%A1%E6%8F%90%E4%BE%9B%E5%95%86%E6%88%96%E7%BD%91%E7%BB%9C%E5%B0%81%E9%94%81%E4%BA%86%E4%B8%8A%E8%BF%B0%20URL%EF%BC%8C%3CBR%20%2F%3E%20%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E5%85%B6%E4%BB%96%E5%9F%9F%E5%90%8D%EF%BC%8C%E4%BE%8B%E5%A6%82%E8%AE%BE%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3E%20CONNECTIVITY_CHECK_URIS%20%3D%20%22%3CA%20href%3D%22https%3A%2F%2Fwww.example.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20https%3A%2F%2Fwww.example.com%2F%3C%2FA%3E%20%22%E4%B9%9F%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%20BB_NO_NETWORK%20%3D%221%22%20%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%89%80%E6%9C%89%E9%9C%80%E8%A6%81%E7%9A%84%E6%BA%90%E9%83%BD%E5%9C%A8%E6%9C%AC%E5%9C%B0%E7%A3%81%E7%9B%98%E4%B8%8A%EF%BC%8C%E5%88%99%E7%A6%81%E6%AD%A2%E7%BD%91%E7%BB%9C%3CBR%20%2F%3E%E8%AE%BF%E9%97%AE%E3%80%82%3CBR%20%2F%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%9C%89%201%20%E6%9D%A1%20ERROR%20%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E8%AF%95%E8%BF%87%E5%85%B6%E4%BB%96%E4%BB%A5%E5%89%8D%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%8C%E4%BD%86%E9%83%BD%E5%8F%91%E7%94%9F%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%90%AF%E5%8A%A8%E5%85%B6%E4%BB%96bitbakes%EF%BC%8C%E4%B9%9F%E4%BC%9A%E5%8F%91%E7%94%9F%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%EF%BC%8C%3CBR%20%2F%3EDaniel%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX95%3A%20Compilation%20error%20with%20bitbake.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX95%3A%20Compilation%20error%20with%20bitbake.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E7%9B%B4%E6%8E%A5%E5%90%91%20Variscite%20%E6%9F%A5%E8%AF%A2%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E7%9A%84%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%20%E5%B7%B2%E7%BB%8F%E5%BB%BA%E6%88%90%EF%BC%8C%E8%A6%81%E6%B1%82%E4%B9%9F%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E8%BF%99%E6%98%AF%E5%90%A6%E6%98%AF%E9%85%8D%E6%96%B9%E4%B8%AD%E7%9A%84%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%96%E8%80%85%E7%94%B1%E4%BA%8E%E5%87%BA%E7%8E%B0%E6%8F%90%E5%8F%96%E9%94%99%E8%AF%AF%E8%80%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E6%9F%90%E7%A7%8D%E9%98%B2%E7%81%AB%E5%A2%99%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
