iMX93 LPDDR4x config
andyclayton
I have a custom iMx93 board with 16Gb LPDDR4x fitted (single rank) which works fine, however when I try to use a dual rank LPDDR4x device on the same board the DDR config tool fails the firmware init tests, just hanging on the following command (mw 204B2BB8,1). The board is routed for 2 CS signals and 2 CKE signals for the two ranks. The LPDDR4X part I am having problems with is JSC JSL4BAG167ZAMF-05A, the Micron alternative (MT53E1G16D1FW-046 AIT:A) works fine so I know the layout is good.
andyclayton
Found the problem, the serial port was dying during the test.
yrj
HI @andyclayton
     1.May I ask if you successfully transplanted JSL4BAG167ZAMF, and if you could share your experience?
Rita_Wang
Dual rank single channel devices are supported therefore, 16Gb/2GB density can be also achieved by using a dual rank single channel device with 16-row addresses (R0 - R15).
Have you configurate the LPRRD4X proper, you can share your configuration to us first.
andyclayton
Configuration attached. I've also tried single rank 8Gb/1GB settings as well.
andyclayton
Here's the debug output from the config tool :-
#################### Result for: phy_init ###### Run 1 #############################################Microsoft Windows [Version 10.0.26100.4652]
(c) Microsoft Corporation. All rights reserved.
C:\nxp\i.MX_CFG_25.03\bin>prompt test-prefix :
test-prefix : "C:/nxp/i.MX_CFG_25.03/bin/python3/python" "C:/nxp/i.MX_CFG_25.03/bin/python3/memtool/memtool_entry.py" -t "runtest" -d "C:/ProgramData/NXP/mcu_data_25.03/processors/MIMX9332xxxxM/ksdk2_0/mem_validation/ddrc" -p "C:/Users/andyc/AppData/Local/Temp/mem_validation/phy_training_phy_test_0_0_.log" -l DEBUG "C:/Users/andyc/AppData/Local/Temp/mem_validation/connect.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/test.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/phy.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_registers.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config_in.json"
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/connect.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/test.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/phy.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_registers.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config_in.json
DEBUG memtool.common.factories new instance -> {inst}
INFO memtool.processor.imx9.imx9_processor Xls mapping load time 0.010644
DEBUG memtool.rpa.xls_engine_mx9 Set Register Configuration!E8 to Disable
INFO memtool.processor.imx9.imx9_processor Config time 0.000295
INFO memtool.processor.imx9.imx9_processor DS file time 0.215430
DEBUG memtool.processor.imx9.imx9_processor freq_0 set to 3200
INFO memtool.phyinit.phy_init Run phyinit for 2022.01\lpddr4x
DEBUG memtool.phyinit.phy_init Shared library C:\ProgramData\NXP\mcu_data_25.03\processors\MIMX9332xxxxM\ksdk2_0\mem_validation\ddrc\phyinit\sharedlib\phyinit_2022.01_lpddr4x.dll
DEBUG memtool.phyinit.phy_init PHY config file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_config_final.json
DEBUG memtool.phyinit.phy_init Phyinit output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d.txt
DEBUG memtool.phyinit.phy_init Retention output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d_retention.txt
DEBUG memtool.phyinit.out_parser Parse phyinit output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d.txt
DEBUG memtool.phyinit.out_parser Parse retention output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d_retention.txt
DEBUG memtool.phyinit.out_parser Parse state A_BRING_UP_POWER
DEBUG memtool.phyinit.out_parser Parse state C_PHY_INIT_CONFIG(307)
DEBUG memtool.phyinit.out_parser Write PHY CONFIG as txt size 0x20fc to file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_init.c
DEBUG memtool.phyinit.out_parser Write PHY CONFIG as txt size 0xda5 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_init.json
DEBUG memtool.phyinit.out_parser Parse state LOAD_IMEM_1(468)
DEBUG memtool.phyinit.out_parser Parse state D_LOAD_IMEM_1D(488)
DEBUG memtool.phyinit.out_parser Write IMEM 1D as bin size 0x8000 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_1d.bin
DEBUG memtool.phyinit.out_parser Write IMEM 1D as txt size 0x6eb52 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_1d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.E_SET_DFI_CLOCK(16873)
DEBUG memtool.phyinit.out_parser Parse state PHASE.F_LOAD_DMEM_1(16892)
DEBUG memtool.phyinit.out_parser Parse state PHASE.F_LOAD_DMEM_1D(16908)
DEBUG memtool.phyinit.out_parser Write DMEM 1D as bin size 0x67c to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_1d.bin
DEBUG memtool.phyinit.out_parser Write DMEM 1D as txt size 0x5394 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_1d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.G_EXEC_FW(17739)
DEBUG memtool.phyinit.out_parser Parse state PHASE.E_SET_DFI_CLOCK(17815)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_IMEM_2(17819)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_IMEM_2D(17837)
DEBUG memtool.phyinit.out_parser Write IMEM 2D as txt size 0x6c68b to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_2d.txt
DEBUG memtool.phyinit.out_parser Write IMEM 2D as bin size 0x8000 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_2d.bin
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.F_LOAD_DMEM_2(34222)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_DMEM_2D(34243)
DEBUG memtool.phyinit.out_parser Write DMEM 2D as bin size 0x580 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_2d.bin
DEBUG memtool.phyinit.out_parser Write DMEM 2D as txt size 0x460a to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_2d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.G_EXEC_FW(34948)
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.I_LOAD_PIE(35014)
DEBUG memtool.phyinit.out_parser Write PIE as txt size 0x42c3 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\pie.txt
DEBUG memtool.phyinit.out_parser Write PIE as txt size 0x8d02 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\pie.json
DEBUG memtool.phyinit.out_parser Parse state PHASE.H_READ_MSG_BLOCK(35597)
DEBUG memtool.phyinit.out_parser Parse retention register list
INFO memtool.comm.serial_channel Using serial: COM9
DEBUG memtool.comm.serial_channel Channel is not alive
DEBUG spsdk.utils.interfaces.device.usb_device Closing the Interface: OO Blank 93 (0x1FC9, 0x014E)path=b'\\\\?\\hid#vid_1fc9&pid_014e#6&13db141b&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}' sn=''
DEBUG memtool.comm.serial_channel ==================hardware_init=======================
DEBUG memtool.comm.serial_channel Power up ddr...
DEBUG memtool.comm.serial_channel DDRMIX power on done...
DEBUG memtool.comm.serial_channel DDRPHY coldreset...
DEBUG memtool.comm.serial_channel Reset and configure LPI2C...
DEBUG memtool.comm.serial_channel ********Found PMIC PCA945X**********
DEBUG memtool.comm.serial_channel Set VDDQ to 0.6V for LPDDR4X
DEBUG memtool.comm.serial_channel ==================hardware_init exit==================
DEBUG memtool.comm.serial_channel Channel is alive
DEBUG memtool.comm.serial_channel Executing: mw204B2BB8,1
andyclayton
Rita_Wang
Good new and good job!
andyclayton
I now have half the memory working (1GB) by reducing the DDR speed to 3200. If I set the number of ranks to 1 and the memory size the 8Gb then the DDR config tests all pass. If I set the ranks to 2 then the tests start failing.
%3CLINGO-SUB%20id%3D%22lingo-sub-2134932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20a%20custom%20iMx93%20board%20with%2016Gb%20LPDDR4x%20fitted%20(single%20rank)%20which%20works%20fine%2C%20however%20when%20I%20try%20to%20use%20a%20dual%20rank%20LPDDR4x%20device%20on%20the%20same%20board%20the%20DDR%20config%20tool%20fails%20the%20firmware%20init%20tests%2C%20just%20hanging%20on%20the%20following%20command%20(mw%20204B2BB8%2C1).%20The%20board%20is%20routed%20for%202%20CS%20signals%20and%202%20CKE%20signals%20for%20the%20two%20ranks.%20The%20LPDDR4X%20part%20I%20am%20having%20problems%20with%20is%20JSC%26nbsp%3BJSL4BAG167ZAMF-05A%2C%20the%20Micron%20alternative%20(MT53E1G16D1FW-046%20AIT%3AA)%20works%20fine%20so%20I%20know%20the%20layout%20is%20good.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGood%20new%20and%20good%20job!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20now%20have%20half%20the%20memory%20working%20(1GB)%20by%20reducing%20the%20DDR%20speed%20to%203200.%20If%20I%20set%20the%20number%20of%20ranks%20to%201%20and%20the%20memory%20size%20the%208Gb%20then%20the%20DDR%20config%20tests%20all%20pass.%20If%20I%20set%20the%20ranks%20to%202%20then%20the%20tests%20start%20failing.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFound%20the%20problem%2C%20the%20serial%20port%20was%20dying%20during%20the%20test.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EConfiguration%20attached.%20I've%20also%20tried%20single%20rank%208Gb%2F1GB%20settings%20as%20well.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDual%20rank%20single%20channel%20devices%20are%20supported%20therefore%2C%2016Gb%2F2GB%20density%20can%20be%20also%20achieved%20by%20using%20a%20dual%20rank%20single%20channel%20device%20with%2016-row%20addresses%20(R0%20-%20R15).%3C%2FP%3E%0A%3CP%3EHave%20you%20configurate%20the%20LPRRD4X%20proper%2C%20you%20can%20share%20your%20configuration%20to%20us%20first.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2134952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHere's%20the%20debug%20output%20from%20the%20config%20tool%20%3A-%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20Result%20for%3A%20phy_init%20%23%23%23%23%23%23%20Run%201%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23Microsoft%20Windows%20%5BVersion%2010.0.26100.4652%5D%3C%2FP%3E%3CP%3E(c)%20Microsoft%20Corporation.%20All%20rights%20reserved.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EC%3A%5Cnxp%5Ci.MX_CFG_25.03%5Cbin%26gt%3Bprompt%20test-prefix%20%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Etest-prefix%20%3A%20%22C%3A%2Fnxp%2Fi.MX_CFG_25.03%2Fbin%2Fpython3%2Fpython%22%20%22C%3A%2Fnxp%2Fi.MX_CFG_25.03%2Fbin%2Fpython3%2Fmemtool%2Fmemtool_entry.py%22%20-t%20%22runtest%22%20-d%20%22C%3A%2FProgramData%2FNXP%2Fmcu_data_25.03%2Fprocessors%2FMIMX9332xxxxM%2Fksdk2_0%2Fmem_validation%2Fddrc%22%20-p%20%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy_training_phy_test_0_0_.log%22%20-l%20DEBUG%20%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%22%20%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%22%20%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%22%20%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%22%20%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%22%20%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%22%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processor%20Xls%20mapping%20load%20time%200.010644%3C%2FP%3E%3CP%3EDEBUG%20memtool.rpa.xls_engine_mx9%20Set%20Register%20Configuration!E8%20to%20Disable%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processor%20Config%20time%200.000295%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processor%20DS%20file%20time%200.215430%3C%2FP%3E%3CP%3EDEBUG%20memtool.processor.imx9.imx9_processor%20freq_0%20set%20to%203200%3C%2FP%3E%3CP%3EINFO%20memtool.phyinit.phy_init%20Run%20phyinit%20for%202022.01%5Clpddr4x%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.phy_init%20Shared%20library%20C%3A%5CProgramData%5CNXP%5Cmcu_data_25.03%5Cprocessors%5CMIMX9332xxxxM%5Cksdk2_0%5Cmem_validation%5Cddrc%5Cphyinit%5Csharedlib%5Cphyinit_2022.01_lpddr4x.dll%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.phy_init%20PHY%20config%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_config_final.json%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.phy_init%20Phyinit%20output%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.phy_init%20Retention%20output%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d_retention.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20phyinit%20output%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20retention%20output%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d_retention.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20A_BRING_UP_POWER%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20C_PHY_INIT_CONFIG(307)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20PHY%20CONFIG%20as%20txt%20size%200x20fc%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_init.c%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20PHY%20CONFIG%20as%20txt%20size%200xda5%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_init.json%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20LOAD_IMEM_1(468)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20D_LOAD_IMEM_1D(488)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20IMEM%201D%20as%20bin%20size%200x8000%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_1d.bin%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20IMEM%201D%20as%20txt%20size%200x6eb52%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_1d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.E_SET_DFI_CLOCK(16873)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.F_LOAD_DMEM_1(16892)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.F_LOAD_DMEM_1D(16908)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20DMEM%201D%20as%20bin%20size%200x67c%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_1d.bin%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20DMEM%201D%20as%20txt%20size%200x5394%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_1d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.G_EXEC_FW(17739)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.E_SET_DFI_CLOCK(17815)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.D_LOAD_IMEM_2(17819)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.D_LOAD_IMEM_2D(17837)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20IMEM%202D%20as%20txt%20size%200x6c68b%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_2d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20IMEM%202D%20as%20bin%20size%200x8000%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_2d.bin%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.PHASE.F_LOAD_DMEM_2(34222)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.D_LOAD_DMEM_2D(34243)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20DMEM%202D%20as%20bin%20size%200x580%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_2d.bin%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20DMEM%202D%20as%20txt%20size%200x460a%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_2d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.PHASE.G_EXEC_FW(34948)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.PHASE.I_LOAD_PIE(35014)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20PIE%20as%20txt%20size%200x42c3%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cpie.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Write%20PIE%20as%20txt%20size%200x8d02%20to%20file%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cpie.json%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20state%20PHASE.H_READ_MSG_BLOCK(35597)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%20Parse%20retention%20register%20list%3C%2FP%3E%3CP%3EINFO%20memtool.comm.serial_channel%20Using%20serial%3A%20COM9%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20Channel%20is%20not%20alive%3C%2FP%3E%3CP%3EDEBUG%20spsdk.utils.interfaces.device.usb_device%20Closing%20the%20Interface%3A%20OO%20Blank%2093%20(0x1FC9%2C%200x014E)path%3Db'%5C%5C%5C%5C%3F%5C%5Chid%23vid_1fc9%26amp%3Bpid_014e%236%26amp%3B13db141b%26amp%3B0%26amp%3B0000%23%7B4d1e55b2-f16f-11cf-88cb-001111000030%7D'%20sn%3D''%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3Dhardware_init%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20Power%20up%20ddr...%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20DDRMIX%20power%20on%20done...%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20DDRPHY%20coldreset...%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20Reset%20and%20configure%20LPI2C...%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20********Found%20PMIC%20PCA945X**********%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20Set%20VDDQ%20to%200.6V%20for%20LPDDR4X%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3Dhardware_init%20exit%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20Channel%20is%20alive%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20Executing%3A%20mw204B2BB8%2C1%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57446%22%20target%3D%22_blank%22%3E%40andyclayton%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B1.%3CSPAN%3EMay%20I%20ask%20if%20you%20successfully%20transplanted%20JSL4BAG167ZAMF%2C%20and%20if%20you%20could%20share%20your%20experience%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
