iMX93 LPDDR4x config
4,129件の閲覧回数
andyclayton
I have a custom iMx93 board with 16Gb LPDDR4x fitted (single rank) which works fine, however when I try to use a dual rank LPDDR4x device on the same board the DDR config tool fails the firmware init tests, just hanging on the following command (mw 204B2BB8,1). The board is routed for 2 CS signals and 2 CKE signals for the two ranks. The LPDDR4X part I am having problems with is JSC JSL4BAG167ZAMF-05A, the Micron alternative (MT53E1G16D1FW-046 AIT:A) works fine so I know the layout is good.
4,084件の閲覧回数
andyclayton
Found the problem, the serial port was dying during the test.
7 返答(返信)
2,795件の閲覧回数
yrj
HI @andyclayton
     1.May I ask if you successfully transplanted JSL4BAG167ZAMF, and if you could share your experience?
4,095件の閲覧回数
Rita_Wang
Dual rank single channel devices are supported therefore, 16Gb/2GB density can be also achieved by using a dual rank single channel device with 16-row addresses (R0 - R15).
Have you configurate the LPRRD4X proper, you can share your configuration to us first.
4,093件の閲覧回数
andyclayton
Configuration attached. I've also tried single rank 8Gb/1GB settings as well.
4,122件の閲覧回数
andyclayton
Here's the debug output from the config tool :-
#################### Result for: phy_init ###### Run 1 #############################################Microsoft Windows [Version 10.0.26100.4652]
(c) Microsoft Corporation. All rights reserved.
C:\nxp\i.MX_CFG_25.03\bin>prompt test-prefix :
test-prefix : "C:/nxp/i.MX_CFG_25.03/bin/python3/python" "C:/nxp/i.MX_CFG_25.03/bin/python3/memtool/memtool_entry.py" -t "runtest" -d "C:/ProgramData/NXP/mcu_data_25.03/processors/MIMX9332xxxxM/ksdk2_0/mem_validation/ddrc" -p "C:/Users/andyc/AppData/Local/Temp/mem_validation/phy_training_phy_test_0_0_.log" -l DEBUG "C:/Users/andyc/AppData/Local/Temp/mem_validation/connect.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/test.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/phy.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_registers.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config_in.json"
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/connect.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/test.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/phy.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_registers.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config_in.json
DEBUG memtool.common.factories new instance -> {inst}
INFO memtool.processor.imx9.imx9_processor Xls mapping load time 0.010644
DEBUG memtool.rpa.xls_engine_mx9 Set Register Configuration!E8 to Disable
INFO memtool.processor.imx9.imx9_processor Config time 0.000295
INFO memtool.processor.imx9.imx9_processor DS file time 0.215430
DEBUG memtool.processor.imx9.imx9_processor freq_0 set to 3200
INFO memtool.phyinit.phy_init Run phyinit for 2022.01\lpddr4x
DEBUG memtool.phyinit.phy_init Shared library C:\ProgramData\NXP\mcu_data_25.03\processors\MIMX9332xxxxM\ksdk2_0\mem_validation\ddrc\phyinit\sharedlib\phyinit_2022.01_lpddr4x.dll
DEBUG memtool.phyinit.phy_init PHY config file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_config_final.json
DEBUG memtool.phyinit.phy_init Phyinit output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d.txt
DEBUG memtool.phyinit.phy_init Retention output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d_retention.txt
DEBUG memtool.phyinit.out_parser Parse phyinit output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d.txt
DEBUG memtool.phyinit.out_parser Parse retention output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d_retention.txt
DEBUG memtool.phyinit.out_parser Parse state A_BRING_UP_POWER
DEBUG memtool.phyinit.out_parser Parse state C_PHY_INIT_CONFIG(307)
DEBUG memtool.phyinit.out_parser Write PHY CONFIG as txt size 0x20fc to file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_init.c
DEBUG memtool.phyinit.out_parser Write PHY CONFIG as txt size 0xda5 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_init.json
DEBUG memtool.phyinit.out_parser Parse state LOAD_IMEM_1(468)
DEBUG memtool.phyinit.out_parser Parse state D_LOAD_IMEM_1D(488)
DEBUG memtool.phyinit.out_parser Write IMEM 1D as bin size 0x8000 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_1d.bin
DEBUG memtool.phyinit.out_parser Write IMEM 1D as txt size 0x6eb52 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_1d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.E_SET_DFI_CLOCK(16873)
DEBUG memtool.phyinit.out_parser Parse state PHASE.F_LOAD_DMEM_1(16892)
DEBUG memtool.phyinit.out_parser Parse state PHASE.F_LOAD_DMEM_1D(16908)
DEBUG memtool.phyinit.out_parser Write DMEM 1D as bin size 0x67c to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_1d.bin
DEBUG memtool.phyinit.out_parser Write DMEM 1D as txt size 0x5394 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_1d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.G_EXEC_FW(17739)
DEBUG memtool.phyinit.out_parser Parse state PHASE.E_SET_DFI_CLOCK(17815)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_IMEM_2(17819)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_IMEM_2D(17837)
DEBUG memtool.phyinit.out_parser Write IMEM 2D as txt size 0x6c68b to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_2d.txt
DEBUG memtool.phyinit.out_parser Write IMEM 2D as bin size 0x8000 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_2d.bin
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.F_LOAD_DMEM_2(34222)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_DMEM_2D(34243)
DEBUG memtool.phyinit.out_parser Write DMEM 2D as bin size 0x580 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_2d.bin
DEBUG memtool.phyinit.out_parser Write DMEM 2D as txt size 0x460a to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_2d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.G_EXEC_FW(34948)
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.I_LOAD_PIE(35014)
DEBUG memtool.phyinit.out_parser Write PIE as txt size 0x42c3 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\pie.txt
DEBUG memtool.phyinit.out_parser Write PIE as txt size 0x8d02 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\pie.json
DEBUG memtool.phyinit.out_parser Parse state PHASE.H_READ_MSG_BLOCK(35597)
DEBUG memtool.phyinit.out_parser Parse retention register list
INFO memtool.comm.serial_channel Using serial: COM9
DEBUG memtool.comm.serial_channel Channel is not alive
DEBUG spsdk.utils.interfaces.device.usb_device Closing the Interface: OO Blank 93 (0x1FC9, 0x014E)path=b'\\\\?\\hid#vid_1fc9&pid_014e#6&13db141b&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}' sn=''
DEBUG memtool.comm.serial_channel ==================hardware_init=======================
DEBUG memtool.comm.serial_channel Power up ddr...
DEBUG memtool.comm.serial_channel DDRMIX power on done...
DEBUG memtool.comm.serial_channel DDRPHY coldreset...
DEBUG memtool.comm.serial_channel Reset and configure LPI2C...
DEBUG memtool.comm.serial_channel ********Found PMIC PCA945X**********
DEBUG memtool.comm.serial_channel Set VDDQ to 0.6V for LPDDR4X
DEBUG memtool.comm.serial_channel ==================hardware_init exit==================
DEBUG memtool.comm.serial_channel Channel is alive
DEBUG memtool.comm.serial_channel Executing: mw204B2BB8,1
4,085件の閲覧回数
andyclayton
4,051件の閲覧回数
Rita_Wang
Good new and good job!
4,076件の閲覧回数
andyclayton
I now have half the memory working (1GB) by reducing the DDR speed to 3200. If I set the number of ranks to 1 and the memory size the 8Gb then the DDR config tests all pass. If I set the ranks to 2 then the tests start failing.
%3CLINGO-SUB%20id%3D%22lingo-sub-2134932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX93%20LPDDR4x%20%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E16Gb%20LPDDR4x%20(%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF)%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20iMx93%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%20LPDDR4x%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81DDR%20%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20(mw%20204B2BB8%2C1)%20%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%80%812%20%E3%81%A4%E3%81%AE%E3%83%A9%E3%83%B3%E3%82%AF%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%202%20%E3%81%A4%E3%81%AE%20CS%20%E4%BF%A1%E5%8F%B7%E3%81%A8%202%20%E3%81%A4%E3%81%AE%20CKE%20%E4%BF%A1%E5%8F%B7%E3%81%8C%E9%85%8D%E7%B7%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AE%E3%81%82%E3%82%8B%20LPDDR4X%20%E9%83%A8%E5%93%81%E3%81%AF%20JSC%20JSL4BAG167ZAMF-05A%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81Micron%20%E3%81%AE%E4%BB%A3%E6%9B%BF%E5%93%81%20(MT53E1G16D1FW-046%20AIT%3AA)%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81SO%20%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E9%81%A9%E5%88%87%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E6%96%B0%E3%81%97%E3%81%84%E4%BB%95%E4%BA%8B%E3%81%A7%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDDR%20%E9%80%9F%E5%BA%A6%E3%82%92%203200%20%E3%81%AB%E4%B8%8B%E3%81%92%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%8D%8A%E5%88%86%20(1%20GB)%20%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%A9%E3%83%B3%E3%82%AF%E6%95%B0%E3%82%92%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%208Gb%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81DDR%20%E6%A7%8B%E6%88%90%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E5%90%88%E6%A0%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%A9%E3%83%B3%E3%82%AF%E3%82%92%202%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E4%B8%AD%E3%81%AB%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%208Gb%2F1GB%20%E8%A8%AD%E5%AE%9A%E3%82%82%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%8116%20%E8%A1%8C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20(R0%20-%20R15)%20%E3%82%92%E6%8C%81%E3%81%A4%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%A9%E3%83%B3%E3%82%AF%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%2016Gb%2F2GB%20%E3%81%AE%E5%AF%86%E5%BA%A6%E3%82%82%E5%AE%9F%E7%8F%BECAN%E3%80%82%3C%2FP%3E%0A%3CP%3ELPRRD4X%20%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%BE%E3%81%9A%E3%81%AF%E3%81%9D%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%A8%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2134952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A-%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%23%23%20Result%20for%3A%20phy_init%20%23%23%20%23%23%20%23%23%20Run%201%20%23%23%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23Microsoft%20Windows%20%5B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2010.0.26100.4652%5D%3C%2FP%3E%3CP%3E(c)%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%BD%E3%83%95%E3%83%88%E3%82%B3%E3%83%BC%E3%83%9D%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%82%E7%84%A1%E6%96%AD%E8%BB%A2%E8%BC%89%E3%82%92%E7%A6%81%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EC%3A%5Cnxp%5Ci.MX_CFG_25.03%5Cbin%26gt%3B%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%3A%20%22C%3A%2Fnxp%2Fi.MX_CFG_25.03%2Fbin%2Fpython3%2Fpython%22%E3%80%8CC%3A%2Fnxp%2Fi.MX_CFG_25.03%2Fbin%2Fpython3%2Fmemtool%2Fmemtool_entry.py%E3%80%8D-t%20%22runtest%22%20-d%20%22C%3A%2FProgramData%2FNXP%2Fmcu_data_25.03%2Fprocessors%2FMIMX9332xxxxM%2Fksdk2_0%2Fmem_validation%2Fddrc%22-p%20%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy_training_phy_test_0_0_.log%22-l%20DEBUG%20%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%22%20%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%22%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%22%E3%80%8CC%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%E3%80%8D%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%22%22C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%22%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.utils.helper%20*****C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.common.factories%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.processor.imx9.imx9_processorXls%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E6%99%82%E9%96%93%200.010644%3C%2FP%3E%3CP%3Ememtool.rpa.xls_engine_mx9%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E6%A7%8B%E6%88%90E8%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.processor.imx9.imx9_processor%E8%A8%AD%E5%AE%9A%E6%99%82%E9%96%93%200.000295%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.processor.imx9.imx9_processorDS%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E6%99%82%E9%96%93%200.215430%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5.imx9.imx9_%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5freq_0%E3%82%923200%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.phyinit.phy_init2022.01%5Clpddr4x%20%E3%81%AE%20phyinit%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.phyinit.phy_init%E5%85%B1%E6%9C%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20C%3A%5CProgramData%5CNXP%5Cmcu_data_25.03%5C%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%5CMIMX9332xxxxM%5Cksdk2_0%5Cmem_validation%5Cddrc%5Cphyinit%5Csharedlib%5Cphyinit_2022.01_lpddr4x.dll%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.common.factories%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.phyinit.phy_initPHY%20%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_config_final.json%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.phyinit.phy_initPhyinit%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d.txt%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.phyinit.phy_init%E4%BF%9D%E6%8C%81%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d_retention.txt%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0phyinit%20%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d.txt%20%E3%82%92%E8%A7%A3%E6%9E%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%BF%9D%E6%8C%81%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d_retention.txt%20%E3%82%92%E8%A7%A3%E6%9E%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20A_BRING_UP_POWER%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20C_PHY_INIT_CONFIG(307)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0PHY%20CONFIG%20%E3%82%92%20txt%20%E3%82%B5%E3%82%A4%E3%82%BA%200x20fc%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_init.c%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0PHY%20CONFIG%20%E3%82%92%20txt%20%E3%82%B5%E3%82%A4%E3%82%BA%200xda5%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_init.json%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20LOAD_IMEM_1(468)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20D_LOAD_IMEM_1D(488)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0IMEM%201D%20%E3%82%92%20bin%20%E3%82%B5%E3%82%A4%E3%82%BA%200x8000%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_1d.bin%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0IMEM%201D%20%E3%82%92%20txt%20%E3%82%B5%E3%82%A4%E3%82%BA%200x6eb52%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_1d.txt%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.E_SET_DFI_CLOCK(16873)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.F_LOAD_DMEM_1(16892)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.F_LOAD_DMEM_1D(16908)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0DMEM%201D%20%E3%82%92%20bin%20%E3%82%B5%E3%82%A4%E3%82%BA%200x67c%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_1d.bin%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0DMEM%201D%20%E3%82%92%20txt%20%E3%82%B5%E3%82%A4%E3%82%BA%200x5394%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_1d.txt%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.G_EXEC_FW(17739)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.E_SET_DFI_CLOCK(17815)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.D_LOAD_IMEM_2(17819)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.D_LOAD_IMEM_2D(17837)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0IMEM%202D%20%E3%82%92%20txt%20%E3%82%B5%E3%82%A4%E3%82%BA%200x6c68b%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_2d.txt%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0IMEM%202D%20%E3%82%92%20bin%20%E3%82%B5%E3%82%A4%E3%82%BA%200x8000%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_2d.bin%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.PHASE.F_LOAD_DMEM_2(34222)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.D_LOAD_DMEM_2D(34243)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0DMEM%202D%20%E3%82%92%20bin%20%E3%82%B5%E3%82%A4%E3%82%BA%200x580%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_2d.bin%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0DMEM%202D%20%E3%82%92%20txt%20%E3%82%B5%E3%82%A4%E3%82%BA%200x460a%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_2d.txt%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.PHASE.G_EXEC_FW(34948)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.PHASE.I_LOAD_PIE(35014)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0PIE%20%E3%82%92%20txt%20%E3%82%B5%E3%82%A4%E3%82%BA%200x42c3%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cpie.txt%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0PIE%20%E3%82%92%20txt%20%E3%82%B5%E3%82%A4%E3%82%BA%200x8d02%20%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20C%3A%5C%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cpie.json%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%85%8B%20PHASE.H_READ_MSG_BLOCK(35597)%3C%2FP%3E%3CP%3Ememtool.phyinit.out_parser%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%A7%A3%E6%9E%90%E4%BF%9D%E6%8C%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%AA%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%20memtool.comm.serial_channel%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E4%BD%BF%E7%94%A8%3A%20COM9%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.common.factories%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.common.factories%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.common.factories%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3Ememtool.comm.serial_channel%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Espsdk.utils.interfaces.device.usb_device%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E9%96%89%E3%81%98%E3%82%8B%3A%20OO%20%E7%A9%BA%E7%99%BD%2093%20(0x1FC9%2C%200x014E)path%3Db'%5C%5C%5C%5C%3F%5C%5Chid%23vid_1fc9%26amp%3Bpid_014e%236%26amp%3B13db141b%26amp%3B0%26amp%3B0000%23%7B4d1e55b2-f16f-11cf-88cb-001111000030%7D'%20sn%3D''%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3Dhardware_init%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20Power%20up%20ddr...%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20DDRMIX%20power%20on%20done...%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20DDRPHY%20coldreset...%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3Ememtool.comm.serial_channel%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0LPI2C%20%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20********Found%20PMIC%20PCA945X**********%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3Ememtool.comm.serial_channel%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0LPDDR4X%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFVDDQ%E3%82%920.6V%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3Dhardware_init%20exit%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3Ememtool.comm.serial_channel%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AF%E7%94%9F%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ememtool.comm.serial_channel%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%AE%9F%E8%A1%8C%E4%B8%AD%3A%20mw204B2BB8%2C1%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57446%22%20target%3D%22_blank%22%3E%40andyclayton%3C%2FA%3E%3C%2FP%3E%3CP%3E1.%20%3CSPAN%3EJSL4BAG167ZAMF%20%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81%E3%81%9D%E3%81%AE%E7%B5%8C%E9%A8%93%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
