iMX93 LPDDR4x config
4,135 次查看
andyclayton
I have a custom iMx93 board with 16Gb LPDDR4x fitted (single rank) which works fine, however when I try to use a dual rank LPDDR4x device on the same board the DDR config tool fails the firmware init tests, just hanging on the following command (mw 204B2BB8,1). The board is routed for 2 CS signals and 2 CKE signals for the two ranks. The LPDDR4X part I am having problems with is JSC JSL4BAG167ZAMF-05A, the Micron alternative (MT53E1G16D1FW-046 AIT:A) works fine so I know the layout is good.
4,090 次查看
andyclayton
Found the problem, the serial port was dying during the test.
7 回复数
2,801 次查看
yrj
HI @andyclayton
     1.May I ask if you successfully transplanted JSL4BAG167ZAMF, and if you could share your experience?
4,101 次查看
Rita_Wang
Dual rank single channel devices are supported therefore, 16Gb/2GB density can be also achieved by using a dual rank single channel device with 16-row addresses (R0 - R15).
Have you configurate the LPRRD4X proper, you can share your configuration to us first.
4,099 次查看
andyclayton
Configuration attached. I've also tried single rank 8Gb/1GB settings as well.
4,128 次查看
andyclayton
Here's the debug output from the config tool :-
#################### Result for: phy_init ###### Run 1 #############################################Microsoft Windows [Version 10.0.26100.4652]
(c) Microsoft Corporation. All rights reserved.
C:\nxp\i.MX_CFG_25.03\bin>prompt test-prefix :
test-prefix : "C:/nxp/i.MX_CFG_25.03/bin/python3/python" "C:/nxp/i.MX_CFG_25.03/bin/python3/memtool/memtool_entry.py" -t "runtest" -d "C:/ProgramData/NXP/mcu_data_25.03/processors/MIMX9332xxxxM/ksdk2_0/mem_validation/ddrc" -p "C:/Users/andyc/AppData/Local/Temp/mem_validation/phy_training_phy_test_0_0_.log" -l DEBUG "C:/Users/andyc/AppData/Local/Temp/mem_validation/connect.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/test.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/phy.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_registers.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config.json" "C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config_in.json"
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/connect.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/test.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/phy.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_registers.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config.json
INFO memtool.utils.helper *****C:/Users/andyc/AppData/Local/Temp/mem_validation/ddrc_config_in.json
DEBUG memtool.common.factories new instance -> {inst}
INFO memtool.processor.imx9.imx9_processor Xls mapping load time 0.010644
DEBUG memtool.rpa.xls_engine_mx9 Set Register Configuration!E8 to Disable
INFO memtool.processor.imx9.imx9_processor Config time 0.000295
INFO memtool.processor.imx9.imx9_processor DS file time 0.215430
DEBUG memtool.processor.imx9.imx9_processor freq_0 set to 3200
INFO memtool.phyinit.phy_init Run phyinit for 2022.01\lpddr4x
DEBUG memtool.phyinit.phy_init Shared library C:\ProgramData\NXP\mcu_data_25.03\processors\MIMX9332xxxxM\ksdk2_0\mem_validation\ddrc\phyinit\sharedlib\phyinit_2022.01_lpddr4x.dll
DEBUG memtool.phyinit.phy_init PHY config file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_config_final.json
DEBUG memtool.phyinit.phy_init Phyinit output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d.txt
DEBUG memtool.phyinit.phy_init Retention output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d_retention.txt
DEBUG memtool.phyinit.out_parser Parse phyinit output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d.txt
DEBUG memtool.phyinit.out_parser Parse retention output file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_training_out_1d2d_retention.txt
DEBUG memtool.phyinit.out_parser Parse state A_BRING_UP_POWER
DEBUG memtool.phyinit.out_parser Parse state C_PHY_INIT_CONFIG(307)
DEBUG memtool.phyinit.out_parser Write PHY CONFIG as txt size 0x20fc to file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_init.c
DEBUG memtool.phyinit.out_parser Write PHY CONFIG as txt size 0xda5 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\phy_init.json
DEBUG memtool.phyinit.out_parser Parse state LOAD_IMEM_1(468)
DEBUG memtool.phyinit.out_parser Parse state D_LOAD_IMEM_1D(488)
DEBUG memtool.phyinit.out_parser Write IMEM 1D as bin size 0x8000 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_1d.bin
DEBUG memtool.phyinit.out_parser Write IMEM 1D as txt size 0x6eb52 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_1d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.E_SET_DFI_CLOCK(16873)
DEBUG memtool.phyinit.out_parser Parse state PHASE.F_LOAD_DMEM_1(16892)
DEBUG memtool.phyinit.out_parser Parse state PHASE.F_LOAD_DMEM_1D(16908)
DEBUG memtool.phyinit.out_parser Write DMEM 1D as bin size 0x67c to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_1d.bin
DEBUG memtool.phyinit.out_parser Write DMEM 1D as txt size 0x5394 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_1d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.G_EXEC_FW(17739)
DEBUG memtool.phyinit.out_parser Parse state PHASE.E_SET_DFI_CLOCK(17815)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_IMEM_2(17819)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_IMEM_2D(17837)
DEBUG memtool.phyinit.out_parser Write IMEM 2D as txt size 0x6c68b to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_2d.txt
DEBUG memtool.phyinit.out_parser Write IMEM 2D as bin size 0x8000 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\imem_2d.bin
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.F_LOAD_DMEM_2(34222)
DEBUG memtool.phyinit.out_parser Parse state PHASE.D_LOAD_DMEM_2D(34243)
DEBUG memtool.phyinit.out_parser Write DMEM 2D as bin size 0x580 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_2d.bin
DEBUG memtool.phyinit.out_parser Write DMEM 2D as txt size 0x460a to file C:\Users\andyc\AppData\Local\Temp\mem_validation\dmem_2d.txt
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.G_EXEC_FW(34948)
DEBUG memtool.phyinit.out_parser Parse state PHASE.PHASE.I_LOAD_PIE(35014)
DEBUG memtool.phyinit.out_parser Write PIE as txt size 0x42c3 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\pie.txt
DEBUG memtool.phyinit.out_parser Write PIE as txt size 0x8d02 to file C:\Users\andyc\AppData\Local\Temp\mem_validation\pie.json
DEBUG memtool.phyinit.out_parser Parse state PHASE.H_READ_MSG_BLOCK(35597)
DEBUG memtool.phyinit.out_parser Parse retention register list
INFO memtool.comm.serial_channel Using serial: COM9
DEBUG memtool.comm.serial_channel Channel is not alive
DEBUG spsdk.utils.interfaces.device.usb_device Closing the Interface: OO Blank 93 (0x1FC9, 0x014E)path=b'\\\\?\\hid#vid_1fc9&pid_014e#6&13db141b&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}' sn=''
DEBUG memtool.comm.serial_channel ==================hardware_init=======================
DEBUG memtool.comm.serial_channel Power up ddr...
DEBUG memtool.comm.serial_channel DDRMIX power on done...
DEBUG memtool.comm.serial_channel DDRPHY coldreset...
DEBUG memtool.comm.serial_channel Reset and configure LPI2C...
DEBUG memtool.comm.serial_channel ********Found PMIC PCA945X**********
DEBUG memtool.comm.serial_channel Set VDDQ to 0.6V for LPDDR4X
DEBUG memtool.comm.serial_channel ==================hardware_init exit==================
DEBUG memtool.comm.serial_channel Channel is alive
DEBUG memtool.comm.serial_channel Executing: mw204B2BB8,1
4,091 次查看
andyclayton
4,057 次查看
Rita_Wang
Good new and good job!
4,082 次查看
andyclayton
I now have half the memory working (1GB) by reducing the DDR speed to 3200. If I set the number of ranks to 1 and the memory size the 8Gb then the DDR config tests all pass. If I set the ranks to 2 then the tests start failing.
%3CLINGO-SUB%20id%3D%22lingo-sub-2134932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX93%20LPDDR4x%20%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E5%9D%97%E8%A3%85%E6%9C%89%2016Gb%20LPDDR4x%EF%BC%88%E5%8D%95%E5%88%97%EF%BC%89%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%20imx93%20%E6%9D%BF%EF%BC%8C%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E5%90%8C%E4%B8%80%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%8F%8C%E5%88%97%20LPDDR4x%20%E8%AE%BE%E5%A4%87%E6%97%B6%EF%BC%8CDDR%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%E5%9B%BA%E4%BB%B6%E5%88%9D%E5%A7%8B%E5%8C%96%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%8C%82%E6%96%AD%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%88mw%20204B2BB8%2C1%EF%BC%89%E3%80%82%E8%AF%A5%E6%9D%BF%E8%B7%AF%E7%94%B1%E4%B8%A4%E4%B8%AA%E7%AD%89%E7%BA%A7%E7%9A%84%202%20%E4%B8%AA%20CS%20%E4%BF%A1%E5%8F%B7%E5%92%8C%202%20%E4%B8%AA%20CKE%20%E4%BF%A1%E5%8F%B7%E3%80%82%E6%88%91%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%E7%9A%84%20LPDDR4X%20%E9%83%A8%E4%BB%B6%E6%98%AF%20JSC%20JSL4BAG167ZAMF-05A%EF%BC%8C%E7%BE%8E%E5%85%89%E7%9A%84%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%88MT53E1G16D1FW-046%20AIT%3AA%EF%BC%89%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E7%9F%A5%E9%81%93%E5%B8%83%E5%B1%80%E6%98%AF%E5%A5%BD%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%96%B0%E7%9A%84%E5%A5%BD%EF%BC%8C%E5%B9%B2%E5%BE%97%E5%A5%BD%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%80%9A%E8%BF%87%E5%B0%86%20DDR%20%E9%80%9F%E5%BA%A6%E9%99%8D%E8%87%B3%203200%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%B8%80%E5%8D%8A%E7%9A%84%E5%86%85%E5%AD%98%EF%BC%881GB%EF%BC%89%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%86%E7%BA%A7%E6%95%B0%E8%AE%BE%E4%B8%BA%201%EF%BC%8C%E5%86%85%E5%AD%98%E5%A4%A7%E5%B0%8F%E8%AE%BE%E4%B8%BA%208Gb%EF%BC%8C%E9%82%A3%E4%B9%88%20DDR%20%E9%85%8D%E7%BD%AE%E6%B5%8B%E8%AF%95%E5%85%A8%E9%83%A8%E9%80%9A%E8%BF%87%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%86%E7%AD%89%E7%BA%A7%E8%AE%BE%E7%BD%AE%E4%B8%BA%202%EF%BC%8C%E6%B5%8B%E8%AF%95%E5%B0%B1%E4%BC%9A%E5%BC%80%E5%A7%8B%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E9%A2%98%E6%89%BE%E5%88%B0%E4%BA%86%EF%BC%8C%E4%B8%B2%E8%A1%8C%E7%AB%AF%E5%8F%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%AD%BB%E6%9C%BA%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%85%8D%E7%BD%AE%E9%99%84%E5%90%8E%E3%80%82%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E8%BF%87%E5%8D%95%E6%8E%92%208GB%2F1GB%20%E7%9A%84%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%94%AF%E6%8C%81%E5%8F%8C%E5%88%97%E5%8D%95%E9%80%9A%E9%81%93%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%85%B7%E6%9C%89%2016%20%E8%A1%8C%E5%9C%B0%E5%9D%80%EF%BC%88R0-R15%EF%BC%89%E7%9A%84%E5%8F%8C%E5%88%97%E5%8D%95%E9%80%9A%E9%81%93%E8%AE%BE%E5%A4%87%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%AE%9E%E7%8E%B0%2016GB%2F2GB%20%E7%9A%84%E5%AF%86%E5%BA%A6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E9%85%8D%E7%BD%AE%E4%BA%86%20LPRRD4X%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2134952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134952%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E7%9A%84%E8%B0%83%E8%AF%95%E8%BE%93%E5%87%BA%20%3A-%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20Result%20for%3A%20phy_init%20%23%23%23%23%23%23%20Run%201%20%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23Microsoft%20Windows%20%5B%E7%89%88%E6%9C%AC%2010.0.26100.4652%5D%3C%2FP%3E%3CP%3E(c)%20%E5%BE%AE%E8%BD%AF%E5%85%AC%E5%8F%B8%E3%80%82%E4%BF%9D%E7%95%99%E6%89%80%E6%9C%89%E6%9D%83%E5%88%A9%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EC%3A%5Cnxp%5Ci.MX_CFG_25.03%5Cbin%26gt%3Bprompttest-prefix%20%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Etest-prefix%20%3A%22C%3A%2Fnxp%2Fi.MX_CFG_25.03%2Fbin%2Fpython3%2Fpython%22%22C%3A%2Fnxp%2Fi.MX_CFG_25.03%2Fbin%2Fpython3%2Fmemtool%2Fmemtool_entry.py%22-t%22runtest%22%20-d%22C%3A%2FProgramData%2FNXP%2Fmcu_data_25.03%2Fprocessors%2FMIMX9332xxxxM%2Fksdk2_0%2Fmem_validation%2Fddrc%22-p%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy_training_phy_test_0_0_.log%22-l%20DEBUG%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%22%20%22%20C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%22%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%22%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%22%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%22%22C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%22%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_registers.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config.json%3C%2FP%3E%3CP%3EINFO%20memtool.utils.helper%20*****C%3A%2FUsers%2Fandyc%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fddrc_config_in.json%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processorXls%20%E6%98%A0%E5%B0%84%E5%8A%A0%E8%BD%BD%E6%97%B6%E9%97%B4%200.010644%3C%2FP%3E%3CP%3EDEBUG%20memtool.rpa.xls_engine_mx9%E5%B0%86%E5%AF%84%E5%AD%98%E5%99%A8%E9%85%8D%E7%BD%AE%EF%BC%81E8%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processor%E9%85%8D%E7%BD%AE%E6%97%B6%E9%97%B4%200.000295%3C%2FP%3E%3CP%3EINFO%20memtool.processor.imx9.imx9_processorDS%20%E6%96%87%E4%BB%B6%E6%97%B6%E9%97%B4%200.215430%3C%2FP%3E%3CP%3EDEBUG%20memtool.processor.imx9.imx9_processorfreq_0%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%203200%3C%2FP%3E%3CP%3EINFO%20memtool.phyinit.phy_init%E4%B8%BA%202022.01%5Clpddr4x%20%E8%BF%90%E8%A1%8C%20phyinit%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.phy_init%E5%85%B1%E4%BA%AB%E5%BA%93%20C%3A%5CProgramData%5CNXP%5Cmcu_data_25.03%5Cprocessors%5CMIMX9332xxxxM%5Cksdk2_0%5Cmem_validation%5Cddrc%5Cphyinit%5Csharedlib%5Cphyinit_2022.01_lpddr4x.dll%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.phy_initPHY%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_config_final.json%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.phy_initPhyinit%20%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%20C%3AUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.phy_init%E4%BF%9D%E7%95%99%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d_retention.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%20phyinit%20%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E4%BF%9D%E7%95%99%E8%BE%93%E5%87%BA%E6%96%87%E4%BB%B6%20C%3AUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_training_out_1d2d_retention.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20A_BRING_UP_POWER%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20C_PHY_INIT_CONFIG(307)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%20PHY%20CONFIG%20%E4%BD%9C%E4%B8%BA%E5%A4%A7%E5%B0%8F%E4%B8%BA%200x20fc%20%E7%9A%84%20txt%20%E6%96%87%E4%BB%B6%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_init.c%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%20PHY%20CONFIG%EF%BC%88%E5%A4%A7%E5%B0%8F%E4%B8%BA%200xda5%20%E7%9A%84%20txt%20%E6%96%87%E4%BB%B6%EF%BC%89%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy_init.json%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20LOAD_IMEM_1(468)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20D_LOAD_IMEM_1D(488)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%20IMEM%201D%20%E4%BD%9C%E4%B8%BA%20bin%20%E5%A4%A7%E5%B0%8F%200x8000%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_1d.bin%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%E5%A4%A7%E5%B0%8F%E4%B8%BA%200x6eb52%20%E7%9A%84%20IMEM%201D%20%E4%BD%9C%E4%B8%BA%20txt%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_1d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.E_SET_DFI_CLOCK(16873)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.F_LOAD_DMEM_1(16892)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.F_LOAD_DMEM_1D(16908)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%20DMEM%201D%20%E4%BD%9C%E4%B8%BA%20bin%20%E5%A4%A7%E5%B0%8F%200x67c%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_1d.bin%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%20DMEM%201D%20%E5%86%99%E5%85%A5%E5%A4%A7%E5%B0%8F%E4%B8%BA%200x5394%20%E7%9A%84%20txt%20%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_1d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.G_EXEC_FW(17739)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.E_SET_DFI_CLOCK(17815)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.D_LOAD_IMEM_2(17819)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.D_LOAD_IMEM_2D(17837)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%E5%A4%A7%E5%B0%8F%E4%B8%BA%200x6c68b%20%E7%9A%84%20IMEM%202D%20%E4%BD%9C%E4%B8%BA%20txt%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_2d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%20IMEM%202D%20%E4%BD%9C%E4%B8%BA%20bin%20%E5%A4%A7%E5%B0%8F%200x8000%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cimem_2d.bin%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.PHASE.F_LOAD_DMEM_2(34222)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.D_LOAD_DMEM_2D(34243)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%20DMEM%202D%20%E4%BD%9C%E4%B8%BA%20bin%20%E5%A4%A7%E5%B0%8F%200x580%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_2d.bin%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%E5%A4%A7%E5%B0%8F%E4%B8%BA%200x460a%20%E7%9A%84%20DMEM%202D%20%E4%BD%9C%E4%B8%BA%20txt%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdmem_2d.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.PHASE.G_EXEC_FW(34948)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.PHASE.I_LOAD_PIE(35014)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%E5%A4%A7%E5%B0%8F%E4%B8%BA%200x42c3%20%E7%9A%84%20PIE%20%E4%BD%9C%E4%B8%BA%20txt%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cpie.txt%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E5%B0%86%E5%A4%A7%E5%B0%8F%E4%B8%BA%200x8d02%20%E7%9A%84%20PIE%20%E4%BD%9C%E4%B8%BA%20txt%20%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20C%3A%5CUsers%5Candyc%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cpie.json%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E7%8A%B6%E6%80%81%20PHASE.H_READ_MSG_BLOCK(35597)%3C%2FP%3E%3CP%3EDEBUG%20memtool.phyinit.out_parser%E8%A7%A3%E6%9E%90%E4%BF%9D%E7%95%99%E5%AF%84%E5%AD%98%E5%99%A8%E5%88%97%E8%A1%A8%3C%2FP%3E%3CP%3EINFO%20memtool.comm.serial_channel%E4%BD%BF%E7%94%A8%E4%B8%B2%E8%A1%8CCOM9%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EDEBUG%20memtool.common.factories%20new%20instance%20-%26gt%3B%20%7Binst%7D%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%E9%80%9A%E9%81%93%E4%B8%8D%E5%AD%98%E5%9C%A8%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20spsdk.utils.interfaces.%E8%AE%BE%E5%A4%87.usb_%E8%AE%BE%E5%A4%87%E5%85%B3%E9%97%AD%E6%8E%A5%E5%8F%A3%EF%BC%9AOO%20Blank%2093%20(0x1FC9%2C%200x014E)path%3Db'%5C%5C%5C%5C%3F%5Chid%23vid_1fc9%26amp%3Bpid_014e%236%26amp%3B13db141b%26amp%3B0%26amp%3B0000%23%7B4d1e55b2-f16f-11cf-88cb-001111000030%7D'%20sn%3D'''%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3Dhardware_init%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%E5%90%AF%E5%8A%A8%20DDR...%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channelDDRMIX%20%E5%90%AF%E5%8A%A8%E5%B7%B2%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channelDDRPHY%20%E5%86%B7%E5%A4%8D%E4%BD%8D...%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channelRESET%20%E5%B9%B6%E9%85%8D%E7%BD%AE%20LPI2C...%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel********%E6%89%BE%E5%88%B0%20PMIC%20PCA945X**********%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%E5%B0%86%20LPDDR4X%20%E7%9A%84%20VDDQ%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200.6V%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3Dhardware_init%20%E9%80%80%E5%87%BA%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%20memtool.comm.serial_channel%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%E9%80%9A%E9%81%93%E8%BF%98%E6%B4%BB%E7%9D%80%3C%2FP%3E%3CP%3EDEBUG%20memtool.comm.serial_channel%E6%89%A7%E8%A1%8C%EF%BC%9A%20mw204B2BB8%2C1%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20iMX93%20LPDDR4x%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57446%22%20target%3D%22_blank%22%3E%40andyclayton%3C%2FA%3E%3C%2FP%3E%3CP%3E%20%20%20%20%201%3CSPAN%3E.%E8%AF%B7%E9%97%AE%E6%82%A8%E6%98%AF%E5%90%A6%E6%88%90%E5%8A%9F%E7%A7%BB%E6%A4%8D%E4%BA%86%20JSL4BAG167ZAMF%EF%BC%8C%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%E7%BB%8F%E9%AA%8C%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
