iMX8QM UUU Tool
iMX8QM UUU Tool
prashanthkumar
We are working on iMX8 Quad Max custom board with 4.14.78 Kernel.
For  flashing to eMMC , we are using MFG Tool(UUU)"  from below link.
GitHub - NXPmicro/mfgtools: Freescale/NXP I.MX Chip image deploy tools.
The UUU script file is attached for your reference.
But while flashing its unable to proceed/move further steps as shown below.
user@root$ sudo ./uuu -v ./partition.uuu
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.2.0-0-g194351b
Build in config:
    Pctl     Chip         Vid     Pid     BcdVersion
    SDPS:     MX8QXP        0x1fc9     0x012f     0x0002
    SDPS:     MX8QM         0x1fc9     0x0129     0x0002
    SDP:       MX7D            0x15a2     0x0076
    SDP:       MX6Q            0x15a2     0x0054
    SDP:       MX6D            0x15a2     0x0061
    SDP:       MX6SL          0x15a2     0x0063
    SDP:       MX6SX          0x15a2     0x0071
    SDP:       MX6UL          0x15a2     0x007d
    SDP:       MX6ULL         0x15a2     0x0080
    SDP:       MX6SLL         0x1fc9     0x0128
    SDP:       MX7ULP        0x1fc9     0x0126
    SDP:       MXRT106X    0x1fc9     0x0135
    SDP:       MX8MM         0x1fc9     0x0134
    SDP:       MX8MQ         0x1fc9     0x012b
    SDPU:    SPL                0x0525     0xb4a4
    FBK:                             0x066f     0x9afe
    FBK:                             0x066f     0x9bff
    FB:                               0x0525     0xa4a5
    FB:                               0x18d1     0x0d02
Wait for Known USB Device Appear
New USB Device Attached at 1:8
1:8>Start Cmd:SDPS: boot -f flash_mfg.bin
100%1:8>Okay
1:8>Start Cmd:FB: ucmd setenv fastboot_dev mmc
1:8>Okay
1:8>Start Cmd:FB: ucmd setenv mmcdev 0
1:8>Okay
1:8>Start Cmd:FB: ucmd mmc dev 0
1:8>Okay
1:8>Start Cmd:FB: ucmd setenv fastboot_buffer ${loadaddr}
1:8>Okay
1:8>Start Cmd:FB: download -f Image_MFG
1:8>Okay
1:8>Start Cmd:FB: ucmd setenv fastboot_buffer ${fdt_addr}
1:8>Okay
1:8>Start Cmd:FB: download -f fsl-imx8qm-iwg27m_mfg.dtb
1:8>Okay
1:8>Start Cmd:FB: ucmd setenv fastboot_buffer ${initrd_addr}
1:8>Okay
1:8>Start Cmd:FB: download -f fsl-image-mfgtool-initramfs-imx_mfgtools.cpio.gz.u-boot
1:8>Okay
1:8>Start Cmd:FB: acmd ${kboot} ${loadaddr} ${initrd_addr} ${fdt_addr}
1:8>Okay
Kindly suggest solution to resolve UUU tool flash issue.
Pashanth Kumar K
nandish_sg
Hello  Prashanth.
Are you able to flash the Linux images on eMMC using UUU tool, Because i am also facing the same issue but my board is Evaluation board iMX 8QuadMax MEK, and images are Linux Yocto (5.4 kernel version), i am using the latest UUU tool 1.3.154. if it your issue is resolved please let me know what is the procedure to flash the images on eMMC,
for your reference    https://community.nxp.com/thread/532952 ,
Thanks in advance ,
Best Regards
SGN
prashanthkumar
Hi Igor,
We rebuilt image for custom board with new ddr settings & tested, same observation for UUU Tool flash.
prashanth Kumar K
Hi Prashanth
so, what is "observation" - any logs/messages/steps.
Are you able to run: uuu  flash.bin (new generated uboot image),
as described in sect.3.1.2 Download boot loader for imx8qxp attached document.
prashanthkumar
Hi Igor,
We did DDR stress test on i.MX8QM custom board. That is getting passed with 1200MHz LPDDR4 frequency.
Whether DDR will effect to flashing using  UUU tool ?
prashanth Kumar K
Hi Prashanth
had you rebuilt image for custom board with new ddr settings (found from ddr test), put them in dcd header
imx-scfw-porting-kit/src/scfw_export_mx8qm_b0/platform/board/mx8qm_mek/dcd
SCFW Porting Kit
prashanthkumar
Hi Igor,
We don't have NXP i.MX8QM EVK board here for testing.
Prashanth Kumar K
Hi Prashanth
had you run i.MX8QM ddr test on custom board.
i.MX 8 DRAM Introduction and Tools Overview Plu... | NXP Community
In general procedure is similar as for i.MX8M
i.MX8MSCALE DDR Tool Release
prashanthkumar
Hi Igor,
Still I am facing same issue in given UUU script while flashing the emmc.
Prashanth Kumar K
Hi Prashanth
please try with NXP i.MX8QM EVK board.
prashanthkumar
Is there any additional/extra changes need for uboot & kernel configuration?
Prashanth Kumar K
i.MX 8 Universal Update Utility (UUU) Tools and Pins Tool
one can try attached script.
prashanthkumar
I followed sect.4.2 Universal update utility, and enabled Uboot & Kernel setup config file macros given below.
Uboot - Inside defconfig file
CONFIG_CMD_FASTBOOT=y
CONFIG_USB_FUNCTION_FASTBOOT=y
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_DOWNLOAD=y
CONFIG_USB_GADGET_MANUFACTURER="FSL"
CONFIG_USB_GADGET_VENDOR_NUM=0x0525
CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5
CONFIG_CI_UDC=y
CONFIG_FSL_FASTBOOT=y
CONFIG_FASTBOOT=y
CONFIG_FASTBOOT_BUF_ADDR=0x82800000
# Address need change according ←
system, generally it can be the same as ${LOADADDR}
CONFIG_FASTBOOT_BUF_SIZE=0x40000000
CONFIG_FASTBOOT_FLASH=y
CONFIG_FASTBOOT_FLASH_MMC_DEV=0
CONFIG_EFI_PARTITION=y
CONFIG_ANDROID_BOOT_IMAGE=y
Kernel - Inside defconfig file
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CHIPIDEA=y
CONFIG_USB_CHIPIDEA_OF=y
CONFIG_USB_CHIPIDEA_PCI=y
CONFIG_USB_CHIPIDEA_UDC=y
CONFIG_USB_PHY=y
CONFIG_GENERIC_PHY=y
CONFIG_PHY_FSL_IMX8MQ_USB=y
CONFIG_PHYLIB=y
CONFIG_USB_LIBCOMPOSITE=y
CONFIG_USB_F_ACM=y
CONFIG_USB_U_SERIAL=y
CONFIG_USB_F_SERIAL=y
CONFIG_USB_F_OBEX=y
CONFIG_USB_F_MASS_STORAGE=y
CONFIG_USB_F_FS=y
CONFIG_USB_CONFIGFS_SERIAL=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_FSL_UTP=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_SYSFS=y
Also used "example_kernel_emmc.uuu" script from release Linux Binary Demo Files - i.MX 8QMax MEK .
But still I am facing same flashing issue in UUU tool.
Prashanth Kumar K
Hi Pashanth
one can follow sect.4.2 Universal update utility attached Linux Guide
and use uuu scripts included in Demo Image
