iMX8MPlus HW accelerated JPEG encode
2,169 次查看
EdSutter
Senior Contributor II
Is there any current/planned way to use hardware acceleration to do HW-accelerated JPEG encode fed by a camera (specifically on iMX8MPlus)?
I see several posts with conversations regarding HW-accelerated JPEG encode, but I didn't see any definitive answer/solution to the question.  There are discussions on different VPU implementations on different versions of iMX8, and different ways that the VPU could do this, but I guess what I'm really asking is there an implemented solution that doesn't require VPU expertise...
2,155 次查看
Zhiming_Liu
i.MX8MPlus doesn't support HW JPEG encode, you can see release note:https://www.nxp.com/docs/en/release-note/IMX_LINUX_RELEASE_NOTES.pdf
2,156 次查看
Zhiming_Liu
