iMX8M Plus PCIe BER
iMX8M Plus PCIe BER
3,021 次查看
kentmeyer
Hello!
In our application, we are running the PCIe over a flex cable.
Is there any way to get the BER and/or any other stats on the link quality from the Linux kernel?
Is any stats available in the PCIe PHY registers?
Thanks in advance!
2,963 次查看
igorpadykov
Hi KENT
I got additional update from team :
Our IP has not any register to show BER.
2,988 次查看
igorpadykov
Hi KENT
Is the Bit error rate need to calculate?
https://edadocs.software.keysight.com/kkbopen/how-do-i-measure-the-bit-error-rate-ber-to-a-given-con...
2,981 次查看
kentmeyer
Hello Igor,
Correct, we need to estimate the Bit Error Rate and/or any other characteristics of the PCIe link using the IMX8M Plus SoC capabilities only.
2,964 次查看
igorpadykov
Hi KENT
