iMX8M Plus Ethernet Control by Cortex-M7
waynechung2
I want to control ethernet by Cortex-M7.
Is it possible ?
Thanks.
Wayne.
waynechung2
Hi Aldo,
Does the ethernet RGMII write in "fsl_enet" ?
If we want to modify some setting, Could we modify this file ?
Thanks.
Wayne.
AldoG
The Cortex-M Core are mainly intended for real-time application, delegating the high-speed communications (like ethernet and USB) to the Cortex-A cores.
With the above in account we do not provide an ethernet driver the Cortex M7.
Aldo.
waynechung2
Hi Aldo,
Thank you for the prompt reply.
Could we use the M4 - SDK_2.9 ENET example move to the M7 ?
Thanks.
Wayne.
AldoG
I would not recommend it, but one can take the enet driver and start working from there (fsl_enet), but please note that this is not supported.
Aldo.
waynechung2
Hi Aldo,
Thanks.
Wayne.
