iMX8M Plus Ethernet Control by Cortex-M7
3,233件の閲覧回数
waynechung2
I want to control ethernet by Cortex-M7.
Is it possible ?
Thanks.
Wayne.
3,175件の閲覧回数
waynechung2
Hi Aldo,
Does the ethernet RGMII write in "fsl_enet" ?
If we want to modify some setting, Could we modify this file ?
Thanks.
Wayne.
4 返答(返信)
3,225件の閲覧回数
AldoG
The Cortex-M Core are mainly intended for real-time application, delegating the high-speed communications (like ethernet and USB) to the Cortex-A cores.
With the above in account we do not provide an ethernet driver the Cortex M7.
Aldo.
3,219件の閲覧回数
waynechung2
Hi Aldo,
Thank you for the prompt reply.
Could we use the M4 - SDK_2.9 ENET example move to the M7 ?
Thanks.
Wayne.
3,211件の閲覧回数
AldoG
I would not recommend it, but one can take the enet driver and start working from there (fsl_enet), but please note that this is not supported.
Aldo.
3,176件の閲覧回数
waynechung2
Hi Aldo,
Thanks.
Wayne.
