iMX8 - mini , how to build freeRTOS simple project from the SDK's examples
1,354件の閲覧回数
moranmoran
My HW :  variscite EVB + dart-mx8m-mini som.
- I'm trying to prepare (on eclipse IDE) an environment for developing \ debugging the M4 (freertos) project.
- I've downloaded from MCUXpresso SDK builder --> SDK: 2.10.0.
I couldn't find any guide that explains how to build a full project tree from the SDK freeRTOS example projects.
The example projects include only sources w/o RTOS files.
Is there any full example (with all relevant folders)?
Thanks in advance,
Moran.
2 返答(返信)
1,345件の閲覧回数
AldoG
You may refer to the document Getting Started with MCUXpresso SDK inside the package, you'll find this information in the chapter 2 MCUXpresso SDK board support folders.
Aldo.
1,336件の閲覧回数
moranmoran
Thanks, maybe my question wasn't clear enough.
I'm trying to set eclipse IDE as development & debug environment for M4 (IMX8).
Getting started with SDK structure doesn't help me to build the hello RTOS project on eclipse IDE.
Or I misunderstood something.
I'm sure I'm not the first one that tries to run this example on eclipse.
Thanks in advance,
Moran.
