iMX7D 16-bit DDR3 Implementation Issue
x10
Hi, NXP team
Does iMX7D support 16-bit DDR3 implementation? In RM DDRC_MSTR[13:12] = DATA_BUS_WIDTH = 2'b01: Half DQ bus width to SDRAM-DRAM_DATA[15:0], it seems that DDRC can work with 16-bit DDR3 chip, but it doesn't work with my test. I just want to make sure if iMX7D DDRC can work with 16-bit DDR3 or not, otherwise something wrong in my test.
Thanks!
Cheng Shi
Labels (2)
JorgeCas
Yes, your understanding is correct.
Best regards.
JorgeCas
i.MX7D supports 16/32-bit DDR3L/LPDDR2/LPDDR3-1066 memories.
You can configure this directly in RPA when doing the DDR stress test.
Best regards.
x10
Thanks for quick reply!
As my understanding, the ds file generated by MX7D_DDR3_Register_Programming_Aid_V1_3 can been used to setup 16-bit DDR3(single chip). Is that right?
Cheng Shi
JorgeCas
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2252909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX7D%2016-bit%20DDR3%20Implementation%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20NXP%20team%3C%2FP%3E%3CP%3EDoes%20iMX7D%20support%2016-bit%20DDR3%20implementation%3F%20In%20RM%20DDRC_MSTR%5B13%3A12%5D%20%3D%20DATA_BUS_WIDTH%20%3D%202'b01%3A%20Half%20DQ%20bus%20width%20to%20SDRAM-DRAM_DATA%5B15%3A0%5D%2C%20it%20seems%20that%20DDRC%20can%20work%20with%2016-bit%20DDR3%20chip%2C%20but%20it%20doesn't%20work%20with%20my%20test.%20I%20just%20want%20to%20make%20sure%20if%20iMX7D%20DDRC%20can%20work%20with%2016-bit%20DDR3%20or%20not%2C%20otherwise%20something%20wrong%20in%20my%20test.%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3CP%3ECheng%20Shi%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2252909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX7Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX7D%2016-bit%20DDR3%20Implementation%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3Ei.MX7D%20supports%26nbsp%3B16%2F32-bit%20DDR3L%2FLPDDR2%2FLPDDR3-1066%20memories.%3C%2FP%3E%0A%3CP%3EYou%20can%20configure%20this%20directly%20in%20RPA%20when%20doing%20the%20DDR%20stress%20test.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX7D%2016-bit%20DDR3%20Implementation%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EYes%2C%20your%20understanding%20is%20correct.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX7D%2016-bit%20DDR3%20Implementation%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253836%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20quick%20reply!%3C%2FP%3E%3CP%3EAs%20my%20understanding%2C%20the%20ds%20file%20generated%20by%20MX7D_DDR3_Register_Programming_Aid_V1_3%20can%20been%20used%20to%20setup%2016-bit%20DDR3(single%20chip).%20Is%20that%20right%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%3C%2FP%3E%3CP%3ECheng%20Shi%3C%2FP%3E%3C%2FLINGO-BODY%3E
