iMX6SoloLite processor schematic/PCB symbol
3,731 次查看
Lankor
Can someone from Freescale convert the iMX6SL EVK schematic(SCH-27452_B.DSN) from OrCAD to Altium format? Or convert it into other format that Altium can import. When I tried to import the schematic, it showed "can't recognize the file".
Thanks too much!
3,204 次查看
Yuri
Please try the enclosed (as result of saving as 16.2 version).
4 回复数
3,205 次查看
Yuri
3,204 次查看
Lankor
Thank you, Yuri. I can import it into Altium now.
3,204 次查看
raghavendraanja
Just install the cadence evaluation setup in the system where you have Altium and then import it works.
i have done the translation from .dsn to altium.
3,204 次查看
hippo
you can find an OrCAD DSN file saved at version 16.2
version after 16.2 are not supported on Altium. The original one is 16.3
