iMX6 MIPI error info
2,763 次查看
ashokp
Hi All,
Please let me know is it possible to check the following error in imx6 MIPI interface.
1.Total number of frames received
2. Number of packets with CRC errors
3. Number of frames dropped because of buffer under run
4. Number of frames that were not completed
5. Frames per second
P.Ashok
标签 (3)
标记 (1)
2,589 次查看
ashokp
Hi ,
I am using MIPI_CSI interface and nitrogen 6x board with ubuntu 3.14.2 kernel version. Please update me the above informations supported by linux mipi csi driver also.
P.Ashok
2,587 次查看
igorpadykov
Hi Ashok
I am afraid current driver does not allow to
provide such debug info. One can try to add this to driver
using attached Linux Manual Chapter 20 MIPI CSI2 Driver.
