iMX6 Camera Parallel Interface - BT1120
2,879 次查看
lucazini
Hello, I need to read frames from a camera connected to the camera parallel interface of an imx6.
The camera begins to write full hd progressive frames to the parallel interface following the bt1120 standard as soon as the board boots.
I've started to study some v4l2 tutorials and to look for some examples, but I have no experience at all in writing drivers.
I write to ask some help :smileyhappy: A few hints or pointers to useful documentation or a driver I can use as a starting point would be greatly appreciated!
1,697 次查看
joanxie
for bt1120 inprogressive mode, you can refer to the link as below, hope helpful for you.
<Support BT1120 progressive mode in Mx6Q >.
