i2c slave mode linux kernel module sample
8,912 次查看
gowricp
I'm looking for an example kernel module that does i2c reads and writes where iMX8M Mini is in slave mode and where the reads and writes are interrupt based. The only remotely related sample seems to be:
mxc_i2c_slave_test.c\mxc_i2c_slave_test\test - imx-test - i.MX Driver Test Application Software
but this doesn't quite do what I want. Could someone please give me some pointers?
标记 (2)
8 回复数
7,912 次查看
diegoadrian
Unfortunately, we cannot help you here since the i.MX8M mini is still in preproduction and we do not have access to all the information about the product. In this case, I highly recommend you to go with your FAE they for sure will help you. I apologize for the inconveniences this could give you.
Diego.
7,912 次查看
gowricp
Thanks Diego. I have already written to the FAE. How about the i.MX8M Quad in that case?
7,912 次查看
diegoadrian
I am also reviewing this with your FAE and with the apps engineers if there is an example that could help you. Please, give me a moment until I could have an update.
Diego.
7,912 次查看
gowricp
Hi Diego - Any updates on this?
From what I've read so far, the client driver example here (pointed to by https://www.kernel.org/doc/Documentation/i2c/slave-interface):
linux/i2c-slave-eeprom.c at master · torvalds/linux · GitHub
is somewhat relevant. This assumes a user space instantiation of the i2c client device though.
https://www.kernel.org/doc/Documentation/i2c/instantiating-devices seems to describe how to do this for when the Linux i2c driver is acting as master. At least as far as I can tell.
I need a way of instantiating a kernel space i2c client (slave) whose address I can set as part of struct i2c_client and having my driver callback be called by i2c core when the imx-i2c driver generates an interrupt.
7,911 次查看
diegoadrian
Just to say that I am still reviewing the best solution of this with your FAE.
Diego.
7,912 次查看
diegoadrian
Just to know if you have been contacted by your FAE lately. We have been looking for a solution together.
Diego.
7,912 次查看
gowricp
Hi Diego - We have decided to not pursue this route for performance reasons so we no longer require a solution. Thanks so much for the effort.
7,912 次查看
gowricp
Sounds good. Thanks!
