i.mx8qm DRAM ecc configuration
2,595 次查看
roffelsen
Can someone point me to documentation on how configure, enable, and test DRAM ECC on the i.mx 8QuadMax? IMX8QMRM indicates ECC on DRAM is supported but I can't find any details on how to enable it.
2,502 次查看
Zhiming_Liu
Correct this answer, i.MX8QM doesn't support ECC, iMX8DXL support this, the ECC keyword  in reference manual and DDR script doesn't mean it supports ECC.
4 回复数
2,587 次查看
roffelsen
I think I have to take that back, the manual mentions ECC in the DDR Controller section but no where do I find it saying it is supported. Given that and the lack of documentation on how to configure it I am guessing ECC on DRAM is not supported.
2,536 次查看
Zhiming_Liu
The default setting has enabled the ecc feature, can you share if you are facing issue in your product.
2,524 次查看
roffelsen
Are you saying  the i.mx8qm supports ecc on DRAM and turns it on by default at processor startup?
If so:
1) Can you point me to where this is documented?
2) What is the processor response when a non-correctable double bit DRAM ecc error occurs?
3) If there a way to inject ecc errors in DRAM so  fault response can be tested?
2,503 次查看
Zhiming_Liu
