Wayland + Weston compositor - How is it possible to place a second window with abs coordinates?
2,188 次查看
MicMoba
Contributor V
on my i.MX8MP system I use the Weston 10.0 compositor. After starting weston I have the Weston desktop on my screen.
Now I want to start a video with GStreamer and place the video with absolute coordinates and and given width and height.
gst-launch-1.0 videotestsrc ! glimagesink render-rectangle="<10,10,200,200>"
Width and height is set as expected but the x- and y-position is random. I read that this is an issue of the wayland protocol.
How can I fix this problem? Any suggestions?
3 回复数
2,138 次查看
Zhiming_Liu
You can try Ubuntu rootfs(Gnome) with this document: https://www.nxp.com/search?keyword=Distribution_POC&start=0
2,126 次查看
MicMoba
Contributor V
Hi Zhiming_Liu,
the key for that possible solution is the different compositor (Gnome), isn't it?
2,082 次查看
Zhiming_Liu
Yes, the wayland protocol using by weston can't support these feature. You need add lots of code in compositor even if you add the wayland protocol support this feature.
