i.mx6 POP packages
i.mx6 POP packages
3,979 次查看
JHY
i.MX 6Dual/6Quad Consumer-PoP Applications Processor
Are POP packages available only in IMX6 Dual or Quad?
Best regards.
3,327 次查看
Yuri
Yes, POP packages available only in IMX6 Dual or Quad, at least right now.
Yuri
4 回复数
3,328 次查看
Yuri
Yuri
3,327 次查看
naoum_gitnik
Zdravstvuyte, Igor and Yuri,
Based on the datasheet mentioned, is my understanding correct that the PoP version has no automotive version?
- If you it does, what is its part number, please?
- If not, are there any plans for it?
Zaranee blagodaren, Naoum Gitnik.
[igorpadykov​]
3,327 次查看
naoum_gitnik
Dear DavidBabin​ and TheAdmiral​,
May you answer this question, please? - Based on the datasheet mentioned above, is my understanding correct that i.MX6 PoP has no automotive version? If not, are there any plans for it?
Sincerely, Naoum Gitnik.
3,327 次查看
Yuri
  I have no information about avilabilty and plans regarding automotive version of the PoP.
Yuri.
