i.mx yocto project build code very slow
2,146 次查看
tzeng015
hi all
I use my notebook to compiler the i.mx yocto project but it is very slow .
How can I do and what can I do ?
Please kindly help me.
thnak you
Jeffrey
2,134 次查看
khang_letruong
Senior Contributor III
To optimize the downloading time, you can edit following variable for saving the packages in a separate place :
DL_DIR ?= "${BSPDIR}/../yocto_dl/v5.10"
Once downloaded, next bitbaking will take less time and avoid issue with the network. Also, packages can also be shared for different working bsp folders to save disk space.
2,138 次查看
Rita_Wang
The build process is long, also the same in our side, it is related by the network and your PC performance.
