i.Mx6 Parallel CSI0 16bit bus width
已解决
跳至解决方案
2,577 次查看
alessandroinnoc
Hi to all !
I am interfacing an ADV7403 to iMX6 DUAL using CSI0 port at 16bit bus width, but I also get
I always get the following kernel error message:
ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0.
Does anyone have any experience on such interfacing ?
Best Regards
Alessandro Innocenti
标签 (1)
1 解答
2,094 次查看
alessandroinnoc
Hi chip
we solved using CSI0 with a bus 8 bit wide and doubling the pixel clock.
Many thanks
ALessandro Innocenti
在原帖中查看解决方案
2 回复数
2,093 次查看
Hi Alessandro
seems this configuration is not supported in kernel,
one can look at similar post below
How to fix the camera timeout error ?
In general new camera needs some support code, for
example ADV7180 below
https://community.freescale.com/message/314760#314760
chip
2,095 次查看
alessandroinnoc
Hi chip
Many thanks
