i.MX8m-mini-bb-evk enable devfreq
2,143 次查看
JamesShih
I'm using iMX8m-mini-bb EVK based on the yocto project base as following SDK.
repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-styhead -m imx-6.12.3-1.0.0.xml
I tried to enable the "devfreq" to control the DRAM clock and see the impact to the power consumption, but unfortunately not able to see the node.
So I did another experiment to enable both "noc" and "devfreq" and I can see the "32700000.noc", but not see the "3d400000.dram-controller".
Attached is my patch and need your kindly help to see if anything missed or something else I have to do?
Thanks.
James Shih
1,848 次查看
JamesShih
5 回复数
2,113 次查看
Bio_TICFSL
That depend on your DDR, it is LPDDR or DDR, you can check this appnote:
https://www.nxp.com/docs/en/application-note/AN12410.pdf
regards
2,099 次查看
JamesShih
Not fully understand and can't find DDR_CTRL related information in the power consumption measurement document, can you please point to me?
Thanks.
2,084 次查看
Bio_TICFSL
You can find the power managment appnote here:
Do not know about ctrl_DDR
2,002 次查看
JamesShih
Not fully understand what you would like to point to me, since I just want to get the way to change the clock for the LPDDR4, not sure if my question is clear for you or any other information you want from me?
Thanks.
1,849 次查看
JamesShih
