i.MX8MP initramfs failed to take effect in kernel
1,626 次查看
jimmyli
      Below is my steps to build initramfs on i.mx8mp platform, but failed.
      Can you help to check and fix it ?
      Thanks very much.
1>Steps:
a. Create initramfs file directory,using busybox init to boot;
b. Make initramfs file system;
     find ./initramfs | cpio -H newc -o | gzip -9 -n > ./initramfs.cpio.gz
c. Copy initramfs.cpio.gz to kernel project in usr file
d. Open kernel initramfs configuration;
e. Build the kernel
    make Image -j30
2>File Tree:
root@Ubuntu-X64:/mnt/rfs# ./tree initramfs
initramfs
├── bin
   ├── ash -> busybox
   ├── busybox
   ├── cat -> busybox
   ├── chmod -> busybox
   ├── cp -> busybox
   ├── date -> busybox
   ├── dd -> busybox
   ├── df -> busybox
   ├── dmesg -> busybox
   ├── echo -> busybox
   ├── false -> busybox
   ├── getopt -> busybox
   ├── grep -> busybox
   ├── gzip -> busybox
   ├── hostname -> busybox
   ├── kill -> busybox
   ├── ln -> busybox
   ├── login -> busybox
   ├── ls -> busybox
   ├── lsof -> busybox
   ├── mkdir -> busybox
   ├── mknod -> busybox
   ├── more -> busybox
   ├── mount -> busybox
   ├── mv -> busybox
   ├── netstat -> busybox
   ├── nice -> busybox
   ├── ping -> busybox
   ├── ping6 -> busybox
   ├── ps -> busybox
   ├── pwd -> busybox
   ├── rm -> busybox
   ├── sed -> busybox
   ├── sh -> busybox
   ├── sleep -> busybox
   ├── switch_root -> busybox
   ├── sync -> busybox
   ├── tar -> busybox
   ├── touch -> busybox
   ├── true -> busybox
   ├── umount -> busybox
   ├── uname -> busybox
   ├── usleep -> busybox
   └── vi -> busybox
├── boot
├── config
├── data
├── dev
   ├── console
   └── null
├── etc
   ├── group
   ├── gshadow
   ├── host.conf
   ├── hosts
   ├── init.d
   │   ├── rcS
   │   └── udev-post
   ├── inittab
   ├── moduli
   ├── nsswitch.conf
   ├── passwd
   ├── profile
   ├── resolv.conf
   ├── shadow
   ├── shells
   ├── ssh_config
   ├── sshd_config
   ├── sysctl.conf
   └── udev
       ├── rules.d
       └── udev.conf
├── home
├── init -> bin/busybox
├── lib
   ├── libc-2.33.so
   ├── libc.so.6 -> libc-2.33.so
   ├── libm-2.33.so
   ├── libm.so.6 -> libm-2.33.so
   ├── libresolv-2.33.so
   └── libresolv.so.2 -> libresolv-2.33.so
├── media
├── mnt
├── phone
├── proc
├── run
├── sbin
   └── init
├── sys
├── tmp
├── usr
   ├── bin
   ├── driver
   ├── lib
   ├── sbin
   ├── scripts
   │   └── init.sh
   └── share
└── var
Note: attachments are relevant config and boot log.
1,598 次查看
Harvey021
Hi @jimmyli
According to the Kernel panic, suggest to check the followings:
if build the fs for the partition on a Linux OS or not.
if the partition (mmcblk2p7) is correctly set as root or not.
Harvey
1,588 次查看
jimmyli
Hi Harvey,
      Get it.
      Thanks very much.
      I will try as your suggestion.
