i.MX8MP initramfs failed to take effect in kernel
1,612件の閲覧回数
jimmyli
      Below is my steps to build initramfs on i.mx8mp platform, but failed.
      Can you help to check and fix it ?
      Thanks very much.
1>Steps:
a. Create initramfs file directory,using busybox init to boot;
b. Make initramfs file system;
     find ./initramfs | cpio -H newc -o | gzip -9 -n > ./initramfs.cpio.gz
c. Copy initramfs.cpio.gz to kernel project in usr file
d. Open kernel initramfs configuration;
e. Build the kernel
    make Image -j30
2>File Tree:
root@Ubuntu-X64:/mnt/rfs# ./tree initramfs
initramfs
├── bin
   ├── ash -> busybox
   ├── busybox
   ├── cat -> busybox
   ├── chmod -> busybox
   ├── cp -> busybox
   ├── date -> busybox
   ├── dd -> busybox
   ├── df -> busybox
   ├── dmesg -> busybox
   ├── echo -> busybox
   ├── false -> busybox
   ├── getopt -> busybox
   ├── grep -> busybox
   ├── gzip -> busybox
   ├── hostname -> busybox
   ├── kill -> busybox
   ├── ln -> busybox
   ├── login -> busybox
   ├── ls -> busybox
   ├── lsof -> busybox
   ├── mkdir -> busybox
   ├── mknod -> busybox
   ├── more -> busybox
   ├── mount -> busybox
   ├── mv -> busybox
   ├── netstat -> busybox
   ├── nice -> busybox
   ├── ping -> busybox
   ├── ping6 -> busybox
   ├── ps -> busybox
   ├── pwd -> busybox
   ├── rm -> busybox
   ├── sed -> busybox
   ├── sh -> busybox
   ├── sleep -> busybox
   ├── switch_root -> busybox
   ├── sync -> busybox
   ├── tar -> busybox
   ├── touch -> busybox
   ├── true -> busybox
   ├── umount -> busybox
   ├── uname -> busybox
   ├── usleep -> busybox
   └── vi -> busybox
├── boot
├── config
├── data
├── dev
   ├── console
   └── null
├── etc
   ├── group
   ├── gshadow
   ├── host.conf
   ├── hosts
   ├── init.d
   │   ├── rcS
   │   └── udev-post
   ├── inittab
   ├── moduli
   ├── nsswitch.conf
   ├── passwd
   ├── profile
   ├── resolv.conf
   ├── shadow
   ├── shells
   ├── ssh_config
   ├── sshd_config
   ├── sysctl.conf
   └── udev
       ├── rules.d
       └── udev.conf
├── home
├── init -> bin/busybox
├── lib
   ├── libc-2.33.so
   ├── libc.so.6 -> libc-2.33.so
   ├── libm-2.33.so
   ├── libm.so.6 -> libm-2.33.so
   ├── libresolv-2.33.so
   └── libresolv.so.2 -> libresolv-2.33.so
├── media
├── mnt
├── phone
├── proc
├── run
├── sbin
   └── init
├── sys
├── tmp
├── usr
   ├── bin
   ├── driver
   ├── lib
   ├── sbin
   ├── scripts
   │   └── init.sh
   └── share
└── var
Note: attachments are relevant config and boot log.
1,584件の閲覧回数
Harvey021
Hi @jimmyli
According to the Kernel panic, suggest to check the followings:
if build the fs for the partition on a Linux OS or not.
if the partition (mmcblk2p7) is correctly set as root or not.
Harvey
1,574件の閲覧回数
jimmyli
Hi Harvey,
      Get it.
      Thanks very much.
      I will try as your suggestion.
