i.MX8MP: Get unique ID to set FIELD RETURN UID
1,618 次查看
Bayou
The i.MX8MP reference says the unique ID is split over several fuses, but specifically 0x420 seems a bit off. Is 0x420[10:0] leading, or is UNIQUE_ID[42:0] leading? If the former, where are the missing 31 bits?
Thanks in advance.
标记 (3)
1 回复
1,594 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
The 42:0 is the correct value, seems like they missed it and it's an error. But the correct value is 42:0.
