i.MX8M Plus Eval Board Altium Design Files?
已解决
跳至解决方案
3,697 次查看
JEaccelerate
I have found the binary Allegro design files for the i.MX8M Plus eval board (LAY-46370_B.brd), but I am unable to import these files into Altium. Could I have access to the ASCII Altium importable version (*.alg)?
1 解答
3,568 次查看
Manuel_Salas
Hello @JEaccelerate
Yes, I sent you again the correct one.
Best regards.
Salas.
在原帖中查看解决方案
8 回复数
2,684 次查看
sholland96
Can you please share the .alg file with me as well?
3,677 次查看
Manuel_Salas
Hello @JEaccelerate
NXP only provides the Allegro files, you can try converting the allegro files to an Altium files.
Best regards.
Salas.
3,673 次查看
JEaccelerate
The only way to convert into Altium files is with the ASCII (.alg) Allegro file, which is created in Allegro (using Cadence's extracta.exe utility). I do not have Allegro, so I am unable to perform this conversion myself. I've seen threads similar to this on other product lines where tech support was able to email out the .alg version. I would appreciate the same being done for this layout (LAY-46370_B.brd).
3,667 次查看
Manuel_Salas
Hello @JEaccelerate
Yes, I sent you the .alg file directly.
Best regards.
Salas.
3,571 次查看
JEaccelerate
Alejandro,
Have you had a chance to look into this?
3,569 次查看
Manuel_Salas
Hello @JEaccelerate
Best regards.
Salas.
3,565 次查看
JEaccelerate
It worked perfectly. Thank you!
3,634 次查看
JEaccelerate
Thank you for your help, though I think something went wrong with this.
The import didn't work and it looks like the file size is much too small (1kB). From the file name I think the wrong file may have been converted. I believe the file that needs to be converted with extracta.exe is "LAY-46370_B.brd" This brd file is 22.6MB so I imagine the resulting .alg file will be on the order of 10s of MB (if not 100s of MB).
