[i.MX8M Plus] Does i.MX8MPlus ENET1 RGMII interface support RX/TX delay (2ns skew) setting
2,607 次查看
iderzh
Hello NXP team,
The PHY IC which we are going to install doesn't provide RXC/TXC skew configuration,
Is it possible to configure (RGMII-ID skew) by ENET1 configuration registers?
Igor
标记 (4)
2,580 次查看
Zhiming_Liu
Hi @iderzh
Please refer the Reference Manunal, there is no such configuration registers.
Qmiller
2,581 次查看
Zhiming_Liu
Hi @iderzh
Qmiller
2,568 次查看
iderzh
Thank you for your reply, Qmiller.
BR,
Igor
