i.MX8M GPU test oom
已解决
i.MX8M GPU test oom
跳至解决方案
4,012 次查看
m_c
Senior Contributor I
Customer try to running "/unit_tests/GPU/gpu.sh" repeatedly on i.MX8M and found out of memory after a while. Also found the free memory is getting lower.
1. Is there any memory leak in gpu unit test?
2. Increase kernel parameter cma will solve it?
标签 (1)
1 解答
3,929 次查看
Hi m.c.
I sent additional details regarding this issue via mail.
在原帖中查看解决方案
2 回复数
3,814 次查看
CordialMai
Hello m_c:
Have you sloved this issue?
Can you tell me how to slove it,I met a similar issue.
Thank you very much!
Best reguards!
CordialMai
3,930 次查看
Hi m.c.
