i.MX8 OpenGL SC support
4,164件の閲覧回数
anguschen
Hello, Team, can you tell me whether the i.MX8 supports OpenGL SC 1.x ? Thank you!
タグ(1)
3 返答(返信)
4,063件の閲覧回数
gusarambula
Hello Zhouneng Chen,
Open GL support may vary a little for each i.MX8. You can find more details on the documentation. For example, the i.MX8QuadXPlus supports OpenGL 3.0, 2.1,; OpenGL ES 3.1, 3.0, 2.0, and 1.1; OpenCL 1.2 Full Profile and 1.1; OpenVG 1.1.
https://www.nxp.com/docs/en/data-sheet/IMX8QXPAEC.pdf
It is my understanding that OpenGL SC is based on OpenGL ES so even tough it’s not implemented on the Linux BSPs the hardware should be able to handle it. I would double check with Khronos (link below).
https://www.khronos.org/openglsc/
I hope this helps!
4,063件の閲覧回数
anguschen
Hello,gusarambula, thanks for help.
According to the https://www.khronos.org/openglsc/, the OpenGL SC is not just the subset of OpenGL ES, it maybe also has some features not availabe in OpenGL ES. So, it is not clear whether the i.MX support it.
4,063件の閲覧回数
gusarambula
I was checking internally and there is no support for OpenGL SC. However, our Partner CoreAVI does provide support for OpenGL SC in some NXP hardware. I would need to ask you to please contact them directly for more details.
https://coreavi.com/
I hope this helps!
