i.MX8 MAX9296 Stream Problem
kayakaantuna
Hi all,
I can get a stream using the following device-tree settings without an MAX9296 from my camera:
	fragment@7 {
		target = <&i2c_mipi_csi0>;
		__overlay__ {
			#address-cells = <1>;
			#size-cells = <0>;
			status = "okay";
			pinctrl-names = "default";
			pinctrl-0 = <&pinctrl_i2c_mipi_csi0>;
			as0149_mipi_0: as0149_mipi@5d {
					compatible = "as0149";
					reg = <0x5d>;
                clocks = <&xtal24m>;
                clock-names = "xclk";
                csi_id = <0>;
                mclk = <24000000>;
                mclk_source = <0>;
                mipi_csi;
                status = "okay";
                port {
						as0149_mipi_ep_0: endpoint {
                        remote-endpoint = <&mipi_csi0_ep>;
                        data-lanes = <1 2>;
                        clocks-lanes = <0>;
	fragment@8 {
		target = <&i2c_mipi_csi1>;
		__overlay__ {
			#size-cells = <0>;
			status = "okay";
			pinctrl-0 = <&pinctrl_i2c_mipi_csi1>;
			as0149_mipi_1: as0149_mipi@5d {
				reg = <0x5d>;
                csi_id = <0>;
                mclk = <24000000>;
                mclk_source = <0>;
                mipi_csi;
                status = "okay";
                port {
					as0149_mipi_ep_1: endpoint {
                        remote-endpoint = <&mipi_csi1_ep>;
                        data-lanes = <1 2>;
                        clocks-lanes = <0>;
	fragment@9 {
		target = <&irqsteer_csi0>;
		__overlay__ {
			status = "okay";
	fragment@10 {
		target = <&irqsteer_csi1>;
		__overlay__ {
			status = "okay";
	fragment@11 {
		target = <&mipi_csi_0>;
		__overlay__  {
			#size-cells = <0>;
			/delete-property/virtual-channel;
			status = "okay";
			/* Camera 0  MIPI CSI-2 (CSIS0) */
			port@0 {
				reg = <0>;
				mipi_csi0_ep: endpoint {
					remote-endpoint = <&as0149_mipi_ep_0>;
                   	data-lanes = <1 2>;
	fragment@12 {
		target = <&isi_0>;
		__overlay__ {
			status = "okay";
			cap_device {
				status = "okay";
			m2m_device {
				status = "okay";
	fragment@13 {
		target = <&mipi_csi_1>;
		__overlay__  {
			#size-cells = <0>;
			status = "okay";
			/* Camera 1  MIPI CSI-2 (CSIS1) */
			port@1 {
               	reg = <1>;
           		mipi_csi1_ep: endpoint {
					remote-endpoint = <&as0149_mipi_ep_1>;
                   	data-lanes = <1 2>;
	fragment@14 {
		target = <&isi_4>;
		__overlay__ {
			status = "okay";
			cap_device {
				status = "okay";
			m2m_device {
				status = "okay";
However, when I add max9296 driver inside of my camera driver I get the following output:
I check my max9296 and as0149 status registers, both with no error and both stating they are on stream.
Input and output format also seems correct by looking at the dmesg log below:
[ 884.552763] bypass csc
[ 884.555176] input fmt UYVY
[ 884.557914] output fmt UYVY
Only thing that came to my mind right now is the pixel clock. I set it like below at the momment:
port {
					as0149_serdes_ep_0: endpoint {
						data-lanes = <1 2>;
						clocks-lanes = <0>;
						/*clock-noncontinuous;*/
						link-frequencies = /bits/ 64 <833333333>;
						//max-pixel-frequency = /bits/ 64 <100000000>;
						remote-endpoint = <&mipi_csi0_ep_0>;
            port@0 {
                reg = <0>;
                mipi_csi0_ep_0: endpoint {
                    remote-endpoint = <&as0149_serdes_ep_0>;
                    data-lanes = <1 2>;
					csis-hs-settle = <18>;
               		csis-clk-settle = <2>;
					csis-wclk;
does this correct setting for 833333333 pixel clock ? Or these values does nothing ? Can any of you guide me on this one ?
Thanks.
kayakaantuna
Hi @joanxie ,
I debug my way to found a solution for this. Please refer to below patch:
diff --git a/drivers/staging/media/imx/imx8-mipi-csi2.c b/drivers/staging/media/imx/imx8-mipi-csi2.c
index 3c628fb1b..9f47bb9ca 100644
--- a/drivers/staging/media/imx/imx8-mipi-csi2.c
+++ b/drivers/staging/media/imx/imx8-mipi-csi2.c
@@ -332,7 +332,7 @@ static struct mxc_hs_info hs_setting[] = {
 	{1920, 1080, 30, 0x0B},
 	{1920, 1080, 15, 0x10},
+	{1280, 960,  30, 0x6},
 	{1280, 720,  30, 0x11},
 	{1280, 720,  15, 0x16},
so basically, ` link-frequencies = /bits/ 64 <833333333>;` have no use on device tree. instead you need to change the hs clock according to the table below:
as you can see by the table 1.5 Gbps, is what I was needed. Once I set the HS timer for my MIPI data rate, it worked like a charm.
Hopefully it will help someone in the future.
joanxie
could you share the full logfile and dts file? and tell me what bsp version you use
kayakaantuna
Hi @joanxie ,
%3CLINGO-SUB%20id%3D%22lingo-sub-1984693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8%20MAX9296%20Stream%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20all%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20can%20get%20a%20stream%20using%20the%20following%20device-tree%20settings%20without%20an%20MAX9296%20from%20my%20camera%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%2F%20%7B%0A%09fragment%407%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bi2c_mipi_csi0%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c_mipi_csi0%26gt%3B%3B%0A%09%09%09as0149_mipi_0%3A%20as0149_mipi%405d%20%7B%0A%09%09%09%09%09compatible%20%3D%20%22as0149%22%3B%0A%09%09%09%09%09reg%20%3D%20%26lt%3B0x5d%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Bxtal24m%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-names%20%3D%20%22xclk%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20csi_id%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mclk%20%3D%20%26lt%3B24000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mipi_csi%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20port%20%7B%0A%09%09%09%09%09%09as0149_mipi_ep_0%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bmipi_csi0_ep%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks-lanes%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%09%09%09%7D%3B%0A%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%408%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bi2c_mipi_csi1%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c_mipi_csi1%26gt%3B%3B%0A%09%09%09as0149_mipi_1%3A%20as0149_mipi%405d%20%7B%0A%09%09%09%09compatible%20%3D%20%22as0149%22%3B%0A%09%09%09%09reg%20%3D%20%26lt%3B0x5d%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Bxtal24m%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-names%20%3D%20%22xclk%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20csi_id%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mclk%20%3D%20%26lt%3B24000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mipi_csi%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20port%20%7B%0A%09%09%09%09%09as0149_mipi_ep_1%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bmipi_csi1_ep%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks-lanes%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%409%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Birqsteer_csi0%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4010%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Birqsteer_csi1%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4011%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bmipi_csi_0%26gt%3B%3B%0A%09%09__overlay__%20%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09%2Fdelete-property%2Fvirtual-channel%3B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%09%2F*%20Camera%200%20%20MIPI%20CSI-2%20(CSIS0)%20*%2F%0A%09%09%09port%400%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09%09mipi_csi0_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bas0149_mipi_ep_0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4012%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bisi_0%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%09cap_device%20%7B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%0A%0A%09%09%09m2m_device%20%7B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4013%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bmipi_csi_1%26gt%3B%3B%0A%09%09__overlay__%20%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09%2Fdelete-property%2Fvirtual-channel%3B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%09%2F*%20Camera%201%20%20MIPI%20CSI-2%20(CSIS1)%20*%2F%0A%09%09%09port%401%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%09%09mipi_csi1_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bas0149_mipi_ep_1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%09%09%09%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4014%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bisi_4%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%09cap_device%20%7B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%0A%0A%09%09%09m2m_device%20%7B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EHowever%2C%20when%20I%20add%20max9296%20driver%20inside%20of%20my%20camera%20driver%20I%20get%20the%20following%20output%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kayakaantuna_0-1730286144432.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kayakaantuna_0-1730286144432.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307682i50443683D970C434%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kayakaantuna_0-1730286144432.jpeg%22%20alt%3D%22kayakaantuna_0-1730286144432.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EI%20check%20my%20max9296%20and%20as0149%20status%20registers%2C%20both%20with%20no%20error%20and%20both%20stating%20they%20are%20on%20stream.%3CBR%20%2F%3E%3CBR%20%2F%3EInput%20and%20output%20format%20also%20seems%20correct%20by%20looking%20at%20the%20dmesg%20log%20below%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%5B%20884.552763%5D%20bypass%20csc%3CBR%20%2F%3E%5B%20884.555176%5D%20input%20fmt%20UYVY%3CBR%20%2F%3E%5B%20884.557914%5D%20output%20fmt%20UYVY%3CBR%20%2F%3E%3CBR%20%2F%3EOnly%20thing%20that%20came%20to%20my%20mind%20right%20now%20is%20the%20pixel%20clock.%20I%20set%20it%20like%20below%20at%20the%20momment%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eport%20%7B%0A%09%09%09%09%09as0149_serdes_ep_0%3A%20endpoint%20%7B%0A%09%09%09%09%09%09data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%09%09%09%09%09%09clocks-lanes%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09%09%09%09%2F*clock-noncontinuous%3B*%2F%0A%09%09%09%09%09%09link-frequencies%20%3D%20%2Fbits%2F%2064%20%26lt%3B833333333%26gt%3B%3B%0A%09%09%09%09%09%09%2F%2Fmax-pixel-frequency%20%3D%20%2Fbits%2F%2064%20%26lt%3B100000000%26gt%3B%3B%0A%09%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bmipi_csi0_ep_0%26gt%3B%3B%0A%09%09%09%09%09%7D%3B%0A%0A...%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20port%400%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mipi_csi0_ep_0%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bas0149_serdes_ep_0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%09%09%09%09%09csis-hs-settle%20%3D%20%26lt%3B18%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09%09csis-clk-settle%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09%09%09%09csis-wclk%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3Edoes%20this%20correct%20setting%20for%20833333333%20pixel%20clock%20%3F%20Or%20these%20values%20does%20nothing%20%3F%20Can%20any%20of%20you%20guide%20me%20on%20this%20one%20%3F%3C%2FP%3E%3CP%3EThanks.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1984693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%20MAX9296%20Stream%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F39586%22%20target%3D%22_blank%22%3E%40joanxie%3C%2FA%3E%26nbsp%3B%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20debug%20my%20way%20to%20found%20a%20solution%20for%20this.%20Please%20refer%20to%20below%20patch%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Ediff%20--git%20a%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2.c%20b%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2.c%0Aindex%203c628fb1b..9f47bb9ca%20100644%0A---%20a%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2.c%0A%2B%2B%2B%20b%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2.c%0A%40%40%20-332%2C7%20%2B332%2C7%20%40%40%20static%20struct%20mxc_hs_info%20hs_setting%5B%5D%20%3D%20%7B%0A%20%0A%20%09%7B1920%2C%201080%2C%2030%2C%200x0B%7D%2C%0A%20%09%7B1920%2C%201080%2C%2015%2C%200x10%7D%2C%0A-%0A%2B%09%7B1280%2C%20960%2C%20%2030%2C%200x6%7D%2C%0A%20%09%7B1280%2C%20720%2C%20%2030%2C%200x11%7D%2C%0A%20%09%7B1280%2C%20720%2C%20%2015%2C%200x16%7D%2C%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3Eso%20basically%2C%20%60%26nbsp%3Blink-frequencies%20%3D%20%2Fbits%2F%2064%20%26lt%3B833333333%26gt%3B%3B%60%20have%20no%20use%20on%20device%20tree.%20instead%20you%20need%20to%20change%20the%20hs%20clock%20according%20to%20the%20table%20below%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202024-11-04%2009-08-54.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202024-11-04%2009-08-54.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F317646iD917DC0752D9FC72%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202024-11-04%2009-08-54.png%22%20alt%3D%22Screenshot%20from%202024-11-04%2009-08-54.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3CBR%20%2F%3Eas%20you%20can%20see%20by%20the%20table%201.5%20Gbps%2C%20is%20what%20I%20was%20needed.%20Once%20I%20set%20the%20HS%20timer%20for%20my%20MIPI%20data%20rate%2C%20it%20worked%20like%20a%20charm.%3CBR%20%2F%3E%3CBR%20%2F%3EHopefully%20it%20will%20help%20someone%20in%20the%20future.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1986677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%20MAX9296%20Stream%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ecould%20you%20share%20the%20full%20logfile%20and%20dts%20file%3F%20and%20tell%20me%20what%20bsp%20version%20you%20use%3C%2FP%3E%3C%2FLINGO-BODY%3E
