i.MX8 MAX9296 Stream Problem
2,587 次查看
kayakaantuna
Hi all,
I can get a stream using the following device-tree settings without an MAX9296 from my camera:
	fragment@7 {
		target = <&i2c_mipi_csi0>;
		__overlay__ {
			#address-cells = <1>;
			#size-cells = <0>;
			status = "okay";
			pinctrl-names = "default";
			pinctrl-0 = <&pinctrl_i2c_mipi_csi0>;
			as0149_mipi_0: as0149_mipi@5d {
					compatible = "as0149";
					reg = <0x5d>;
                clocks = <&xtal24m>;
                clock-names = "xclk";
                csi_id = <0>;
                mclk = <24000000>;
                mclk_source = <0>;
                mipi_csi;
                status = "okay";
                port {
						as0149_mipi_ep_0: endpoint {
                        remote-endpoint = <&mipi_csi0_ep>;
                        data-lanes = <1 2>;
                        clocks-lanes = <0>;
	fragment@8 {
		target = <&i2c_mipi_csi1>;
		__overlay__ {
			#size-cells = <0>;
			status = "okay";
			pinctrl-0 = <&pinctrl_i2c_mipi_csi1>;
			as0149_mipi_1: as0149_mipi@5d {
				reg = <0x5d>;
                csi_id = <0>;
                mclk = <24000000>;
                mclk_source = <0>;
                mipi_csi;
                status = "okay";
                port {
					as0149_mipi_ep_1: endpoint {
                        remote-endpoint = <&mipi_csi1_ep>;
                        data-lanes = <1 2>;
                        clocks-lanes = <0>;
	fragment@9 {
		target = <&irqsteer_csi0>;
		__overlay__ {
			status = "okay";
	fragment@10 {
		target = <&irqsteer_csi1>;
		__overlay__ {
			status = "okay";
	fragment@11 {
		target = <&mipi_csi_0>;
		__overlay__  {
			#size-cells = <0>;
			/delete-property/virtual-channel;
			status = "okay";
			/* Camera 0  MIPI CSI-2 (CSIS0) */
			port@0 {
				reg = <0>;
				mipi_csi0_ep: endpoint {
					remote-endpoint = <&as0149_mipi_ep_0>;
                   	data-lanes = <1 2>;
	fragment@12 {
		target = <&isi_0>;
		__overlay__ {
			status = "okay";
			cap_device {
				status = "okay";
			m2m_device {
				status = "okay";
	fragment@13 {
		target = <&mipi_csi_1>;
		__overlay__  {
			#size-cells = <0>;
			status = "okay";
			/* Camera 1  MIPI CSI-2 (CSIS1) */
			port@1 {
               	reg = <1>;
           		mipi_csi1_ep: endpoint {
					remote-endpoint = <&as0149_mipi_ep_1>;
                   	data-lanes = <1 2>;
	fragment@14 {
		target = <&isi_4>;
		__overlay__ {
			status = "okay";
			cap_device {
				status = "okay";
			m2m_device {
				status = "okay";
However, when I add max9296 driver inside of my camera driver I get the following output:
I check my max9296 and as0149 status registers, both with no error and both stating they are on stream.
Input and output format also seems correct by looking at the dmesg log below:
[ 884.552763] bypass csc
[ 884.555176] input fmt UYVY
[ 884.557914] output fmt UYVY
Only thing that came to my mind right now is the pixel clock. I set it like below at the momment:
port {
					as0149_serdes_ep_0: endpoint {
						data-lanes = <1 2>;
						clocks-lanes = <0>;
						/*clock-noncontinuous;*/
						link-frequencies = /bits/ 64 <833333333>;
						//max-pixel-frequency = /bits/ 64 <100000000>;
						remote-endpoint = <&mipi_csi0_ep_0>;
            port@0 {
                reg = <0>;
                mipi_csi0_ep_0: endpoint {
                    remote-endpoint = <&as0149_serdes_ep_0>;
                    data-lanes = <1 2>;
					csis-hs-settle = <18>;
               		csis-clk-settle = <2>;
					csis-wclk;
does this correct setting for 833333333 pixel clock ? Or these values does nothing ? Can any of you guide me on this one ?
Thanks.
2,349 次查看
kayakaantuna
Hi @joanxie ,
I debug my way to found a solution for this. Please refer to below patch:
diff --git a/drivers/staging/media/imx/imx8-mipi-csi2.c b/drivers/staging/media/imx/imx8-mipi-csi2.c
index 3c628fb1b..9f47bb9ca 100644
--- a/drivers/staging/media/imx/imx8-mipi-csi2.c
+++ b/drivers/staging/media/imx/imx8-mipi-csi2.c
@@ -332,7 +332,7 @@ static struct mxc_hs_info hs_setting[] = {
 	{1920, 1080, 30, 0x0B},
 	{1920, 1080, 15, 0x10},
+	{1280, 960,  30, 0x6},
 	{1280, 720,  30, 0x11},
 	{1280, 720,  15, 0x16},
so basically, ` link-frequencies = /bits/ 64 <833333333>;` have no use on device tree. instead you need to change the hs clock according to the table below:
as you can see by the table 1.5 Gbps, is what I was needed. Once I set the HS timer for my MIPI data rate, it worked like a charm.
Hopefully it will help someone in the future.
标记 (1)
2,557 次查看
joanxie
could you share the full logfile and dts file? and tell me what bsp version you use
2,350 次查看
kayakaantuna
Hi @joanxie ,
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1984693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8%20MAX9296%20%E6%B5%81%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E8%AE%BE%E5%A4%87%E6%A0%91%E8%AE%BE%E7%BD%AE%E4%BB%8E%E6%88%91%E7%9A%84%E7%9B%B8%E6%9C%BA%E4%B8%AD%E8%8E%B7%E5%8F%96%E6%B5%81%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%20MAX9296%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%20%7B%0A%09fragment%407%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bi2c_mipi_csi0%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c_mipi_csi0%26gt%3B%3B%0A%09%09%09as0149_mipi_0%3A%20as0149_mipi%405d%20%7B%0A%09%09%09%09%09compatible%20%3D%20%22as0149%22%3B%0A%09%09%09%09%09reg%20%3D%20%26lt%3B0x5d%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Bxtal24m%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-names%20%3D%20%22xclk%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20csi_id%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mclk%20%3D%20%26lt%3B24000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mipi_csi%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20port%20%7B%0A%09%09%09%09%09%09as0149_mipi_ep_0%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bmipi_csi0_ep%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks-lanes%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%09%09%09%7D%3B%0A%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%408%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bi2c_mipi_csi1%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c_mipi_csi1%26gt%3B%3B%0A%09%09%09as0149_mipi_1%3A%20as0149_mipi%405d%20%7B%0A%09%09%09%09compatible%20%3D%20%22as0149%22%3B%0A%09%09%09%09reg%20%3D%20%26lt%3B0x5d%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Bxtal24m%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-names%20%3D%20%22xclk%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20csi_id%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mclk%20%3D%20%26lt%3B24000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mipi_csi%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20port%20%7B%0A%09%09%09%09%09as0149_mipi_ep_1%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bmipi_csi1_ep%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks-lanes%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%409%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Birqsteer_csi0%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4010%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Birqsteer_csi1%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4011%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bmipi_csi_0%26gt%3B%3B%0A%09%09__overlay__%20%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09%2Fdelete-property%2Fvirtual-channel%3B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%09%2F*%20Camera%200%20%20MIPI%20CSI-2%20(CSIS0)%20*%2F%0A%09%09%09port%400%20%7B%0A%09%09%09%09reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09%09mipi_csi0_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bas0149_mipi_ep_0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4012%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bisi_0%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%09cap_device%20%7B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%0A%0A%09%09%09m2m_device%20%7B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4013%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bmipi_csi_1%26gt%3B%3B%0A%09%09__overlay__%20%20%7B%0A%09%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09%2Fdelete-property%2Fvirtual-channel%3B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%09%2F*%20Camera%201%20%20MIPI%20CSI-2%20(CSIS1)%20*%2F%0A%09%09%09port%401%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%09%09mipi_csi1_ep%3A%20endpoint%20%7B%0A%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bas0149_mipi_ep_1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%09%09%09%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09fragment%4014%20%7B%0A%09%09target%20%3D%20%26lt%3B%26amp%3Bisi_4%26gt%3B%3B%0A%09%09__overlay__%20%7B%0A%09%09%09status%20%3D%20%22okay%22%3B%0A%0A%09%09%09cap_device%20%7B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%0A%0A%09%09%09m2m_device%20%7B%0A%09%09%09%09status%20%3D%20%22okay%22%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%9C%A8%E7%9B%B8%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%B7%BB%E5%8A%A0%20max9296%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BB%A5%E4%B8%8B%E8%BE%93%E5%87%BA%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kayakaantuna_0-1730286144432.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kayakaantuna_0-1730286144432.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307682i50443683D970C434%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kayakaantuna_0-1730286144432.jpeg%22%20alt%3D%22kayakaantuna_0-1730286144432.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E6%88%91%E7%9A%84%20max9296%20%E5%92%8C%20as0149%20%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E4%B8%A4%E8%80%85%E9%83%BD%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E5%B9%B6%E4%B8%94%E9%83%BD%E8%A1%A8%E6%98%8E%E5%AE%83%E4%BB%AC%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%80%9A%E8%BF%87%E6%9F%A5%E7%9C%8B%E4%B8%8B%E9%9D%A2%E7%9A%84%20dmesg%20%E6%97%A5%E5%BF%97%EF%BC%8C%E8%BE%93%E5%85%A5%E5%92%8C%E8%BE%93%E5%87%BA%E6%A0%BC%E5%BC%8F%E4%BC%BC%E4%B9%8E%E4%B9%9F%E6%AD%A3%E7%A1%AE%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%20%5B884.552763%5D%20%E7%BB%95%E8%BF%87%20CSC%3CBR%20%2F%3E%20%5B%20884.555176%5D%20%E8%BE%93%E5%85%A5%E6%A0%BC%E5%BC%8F%20UYVY%3CBR%20%2F%3E%20%5B884.557914%5D%20%E8%BE%93%E5%87%BA%E6%A0%BC%E5%BC%8F%20UYVY%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%94%AF%E4%B8%80%E6%83%B3%E5%88%B0%E7%9A%84%E5%B0%B1%E6%98%AF%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%E3%80%82%E6%88%91%E7%9B%AE%E5%89%8D%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eport%20%7B%0A%09%09%09%09%09as0149_serdes_ep_0%3A%20endpoint%20%7B%0A%09%09%09%09%09%09data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%09%09%09%09%09%09clocks-lanes%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09%09%09%09%2F*clock-noncontinuous%3B*%2F%0A%09%09%09%09%09%09link-frequencies%20%3D%20%2Fbits%2F%2064%20%26lt%3B833333333%26gt%3B%3B%0A%09%09%09%09%09%09%2F%2Fmax-pixel-frequency%20%3D%20%2Fbits%2F%2064%20%26lt%3B100000000%26gt%3B%3B%0A%09%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Bmipi_csi0_ep_0%26gt%3B%3B%0A%09%09%09%09%09%7D%3B%0A%0A...%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20port%400%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mipi_csi0_ep_0%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bas0149_serdes_ep_0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%26gt%3B%3B%0A%09%09%09%09%09csis-hs-settle%20%3D%20%26lt%3B18%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%09%09csis-clk-settle%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09%09%09%09csis-wclk%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%98%AF%20833333333%20%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%E7%9A%84%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E8%BF%99%E4%BA%9B%E5%80%BC%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E4%BD%9C%E7%94%A8%EF%BC%9F%E4%BD%A0%E4%BB%AC%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E6%8C%87%E5%AF%BC%E6%88%91%E8%BF%99%E4%B8%80%E7%82%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1984693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Ai.MX8%20MAX9296%20%E6%B5%81%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F39586%22%20target%3D%22_blank%22%3E%40joanxie%3C%2FA%3E%20%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E9%80%9A%E8%BF%87%E8%B0%83%E8%AF%95%E6%89%BE%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E8%AF%B7%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E8%A1%A5%E4%B8%81%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Ediff%20--git%20a%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2.c%20b%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2.c%0Aindex%203c628fb1b..9f47bb9ca%20100644%0A---%20a%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2.c%0A%2B%2B%2B%20b%2Fdrivers%2Fstaging%2Fmedia%2Fimx%2Fimx8-mipi-csi2.c%0A%40%40%20-332%2C7%20%2B332%2C7%20%40%40%20static%20struct%20mxc_hs_info%20hs_setting%5B%5D%20%3D%20%7B%0A%20%0A%20%09%7B1920%2C%201080%2C%2030%2C%200x0B%7D%2C%0A%20%09%7B1920%2C%201080%2C%2015%2C%200x10%7D%2C%0A-%0A%2B%09%7B1280%2C%20960%2C%20%2030%2C%200x6%7D%2C%0A%20%09%7B1280%2C%20720%2C%20%2030%2C%200x11%7D%2C%0A%20%09%7B1280%2C%20720%2C%20%2015%2C%200x16%7D%2C%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%E6%89%80%E4%BB%A5%E5%9F%BA%E6%9C%AC%E4%B8%8A%EF%BC%8C%60%20link-frequencies%20%3D%20%2Fbits%2F%2064%20%26lt%3B833333333%26gt%3B%3B%60%20%E5%9C%A8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%8A%E6%B2%A1%E6%9C%89%E7%94%A8%E5%A4%84%E3%80%82%E7%9B%B8%E5%8F%8D%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E6%A0%B9%E6%8D%AE%E4%B8%8B%E8%A1%A8%E6%9B%B4%E6%94%B9%20hs%20%E6%97%B6%E9%92%9F%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202024-11-04%2009-08-54.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202024-11-04%2009-08-54.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F317646iD917DC0752D9FC72%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202024-11-04%2009-08-54.png%22%20alt%3D%22Screenshot%20from%202024-11-04%2009-08-54.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%BB%8E%E8%A1%A8%E4%B8%AD%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%87%BA%EF%BC%8C1.5%20Gbps%20%E6%AD%A3%E6%98%AF%E6%88%91%E6%89%80%E9%9C%80%E8%A6%81%E7%9A%84%E3%80%82%E4%B8%80%E6%97%A6%E6%88%91%E5%B0%86%20HS%20%E8%AE%A1%E6%97%B6%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%88%91%E7%9A%84%20MIPI%20%E6%95%B0%E6%8D%AE%E9%80%9F%E7%8E%87%EF%BC%8C%E5%AE%83%E5%B0%B1%E4%BC%9A%E5%83%8F%E9%AD%94%E6%B3%95%E4%B8%80%E6%A0%B7%E5%B7%A5%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%B8%8C%E6%9C%9B%E5%AE%83%E5%B0%86%E6%9D%A5%E8%83%BD%E5%AF%B9%E6%9F%90%E4%BA%BA%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1986677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Ai.MX8%20MAX9296%20%E6%B5%81%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%88%86%E4%BA%AB%E5%AE%8C%E6%95%B4%E7%9A%84%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%92%8C%20dts%20%E6%96%87%E4%BB%B6%E5%90%97%EF%BC%9F%E5%91%8A%E8%AF%89%E6%88%91%E4%BD%A0%E7%94%A8%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%E7%89%88%E6%9C%AC%E7%9A%84%20BSP%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
