i.MX8 Camera CSI MIPI question
1,577 次查看
xu_ji1
Contributor V
If we want to changed MIPI_CSI_CLK N and P/MIPI_CSI_DATA N and P each other,
like use MIPI_CSI_CLK_N as MIPI_CSI_CLK_P / MIPI_CSI_DATA_N as MIPI_CSI_DATA_P,whereas.
Does it support this on i.MX8 platform?Is there some method to changed in SW side?
1,486 次查看
igorpadykov
Hi Xu
unfortunately such change is not supported in hardware nor software.
1,487 次查看
igorpadykov
Hi Xu
