i.MX7 Sabre HSIC interface
2,353 次查看
agorod
We are working with i.MX7 Sabre evaluation board kernel version 4.9.88 (based on Yocto core-image-base) connected to MicroChip LAN7930-EVB evaluation board by HSIC interface. We do not see activity on HSIC signals: both DATA and STROBE are low. We would appreciate instructions to activate HSIC interface. Do we need to upgrade DTS, compile drivers to kernel? Should HSIC be enabled in uboot and how?
Thank you very much.
Anton.
标签 (2)
标记 (3)
2,108 次查看
Hi Anton
one can look at attached general example for i.MX7ULP and
i.MX7D USB HSIC Hub (USB3503) enumeration variability
In general i.MX7D Sabre board was not tested with HSIC and may not work as
HSIC timings are quite strict, defined in sect.4.10.15 USB HSIC timing
i.MX 7Dual Family of Applications Processors Datasheet
2,109 次查看
Hi Anton
2,108 次查看
agorod
Hello Igor,
Thank you for your answer. The files you sent me are for i.MX7ULP processors. Are they suitable for i.MX7Dual too?
Th HSIC are routed very carefully in both evaluation boards and we are attaching them using dedicated short coaxial cable of equal length. Our problem that we see no activity on these lines and thus assume they have not been enabled in kernel.
Thank you.
Best regards.
Anton.
2,108 次查看
Hi Anton
I am not aware of HSIC software settings for i.MX7D, in general
one can proceed with help NXP Professional Services | NXP
for developing them.
