i.MX6Quad Jumpstart Development Kit
1,069 次查看
vittoria98
Good morning everyone,
I have the Connectcore 6 for i.MX6Quad Jumpstart development kit, and I'm trying to test its JTAG connections.
I've uploaded the netlist, BOM, schematic, and BSDL file. The board is connected to JTAG link2 through  Tag-Connect’s TC2050-IDC-NL “No Legs” Plug-of-Nails™ cable and an ARM 20-pin to ARM 10-pin.
This is the error I get:
Starting Check Chain...
No valid data returned from the JTAG chain.
Perhaps the pin map is incorrect, or the board is not powered.
Check Chain failed
I believe there is a problem with the pin mapping/reset sequence, but I can't figure out what it is; can you help me with that?
Thank you,
Vittoria
1,056 次查看
riteshmpatel
Hi @vittoria98 ,
I hope you are doing well.
Could you please check with the other JTAG device?
Thanks & Regards,
Ritesh M Patel
