hello all,
I am trying to control a small <5V servo motor.
I have Linux knowledge but new to PWM.
doing a bit analysis i found there is support for backlight/led control for pwm, is it possible to use this pwm system to drive servo motor ??.
Kane
Hi kane
I think yes, please look at 8.3 Backlight Control for LCDs
Linux Software User Manual (i.MX6) - BlueWiki
i am using a marsboard from embest:
i tried by adding the below to board-mx6q_marsboard.c
static struct platform_pwm_backlight_data mx6_marsboard_ldb_backlight_data1 = {
.pwm_id = 1,
.max_brightness = 255,
.dft_brightness = 0,
.pwm_period_ns =20000000, //20ms the default cycle time for a 50 hz motor
then
imx6q_add_mxc_pwm_backlight(1, &mx6_marsboard_lcd_backlight_data1);
still no response, however my servo blades move randomly during bootup.
no idea which pwm pulses are driving them.
plz share any example code to control servo using pwm.
i heard the way servo driven by pwm is different from led driven by pwm.
Kane
Please check
https://community.freescale.com/message/433746#433746
i.MX 6Series Platform SDK
: Bare-metal SDK
For Mars board specific questions please post to this
board forum.
