i.MX6 ethernet smartbit test is failed
996 次查看
charleshuang
Senior Contributor II
We did smartbit test on i.MX6 demo board, and found the problem happens at long length packet. Attached the complete test result.
Any suggestion for improving the test result.
Packet
Speed&
Packets
Bytes
Percent
Packets
Packets
Bytes
Bytes
Pct
Packets
Collisions
CRC
Alignment
Oversize
Undersize
Length
Duplex
/Second
/Second
Bandwidth
Sent
Received
Sent
Received
Received
Dropped
Errors
Errors
Errors
Errors
1020
GIG_FULL
11973
12260352
10
119730
119730
122603520
122603520
  1. 100.00
  2. 0.00
0
0
0
0
0
1020
GIG_FULL
23946
24520704
20
239460
126525
245207040
129561600
  1. 52.84
  2. 112935.00
0
0
0
0
0
1020
GIG_FULL
35919
36781056
30
359190
322634
367810560
330377216
  1. 89.82
  2. 36556.00
0
0
0
0
0
1020
GIG_FULL
47892
49041408
40
478920
283627
490414080
290434048
  1. 59.22
  2. 195293.00
0
0
0
0
0
1020
GIG_FULL
59865
61301760
50
598650
254216
613017600
260317184
  1. 42.46
  2. 344434.00
0
0
0
0
0
1020
GIG_FULL
71839
73563136
60
718390
239002
735631360
244738048
  1. 33.27
  2. 479388.00
0
0
0
0
0
1020
GIG_FULL
83836
85848064
70
838360
229989
858480640
235508736
  1. 27.43
  2. 608371.00
0
0
0
0
0
1020
GIG_FULL
95785
98083840
80
957850
225528
980838400
230940672
  1. 23.55
  2. 732322.00
0
0
0
0
0
1020
GIG_FULL
107758
110344192
90
1077580
232826
1103441920
238413824
  1. 21.61
  2. 844754.00
0
0
0
0
0
1020
GIG_FULL
119731
122604544
100
1197310
233618
1226045440
239224832
  1. 19.51
  2. 963692.00
0
0
0
0
0
1276
GIG_FULL
9615
12307200
10
96150
96150
123072000
123072000
  1. 100.00
  2. 0.00
0
0
0
0
0
1276
GIG_FULL
19230
24614400
20
192300
192288
246144000
246128640
  1. 99.99
  2. 12.00
0
0
0
0
0
1276
GIG_FULL
28848
36925440
30
288480
288477
369254400
369250560
  1. 100.00
  2. 3.00
0
0
0
0
0
1276
GIG_FULL
38461
49230080
40
384610
256042
492300800
327733760
  1. 66.57
  2. 128568.00
0
0
0
0
0
1276
GIG_FULL
48076
61537280
50
480760
213448
615372800
273213440
  1. 44.40
  2. 267312.00
0
0
0
0
0
1276
GIG_FULL
57710
73868800
60
577100
213929
738688000
273829120
  1. 37.07
  2. 363171.00
0
0
0
0
0
1276
GIG_FULL
67312
86159360
70
673120
202324
861593600
258974720
  1. 30.06
  2. 470796.00
0
0
0
0
0
1276
GIG_FULL
76923
98461440
80
769230
185972
984614400
238044160
  1. 24.18
  2. 583258.00
0
0
0
0
0
1276
GIG_FULL
86565
110803200
90
865650
189885
1108032000
243052800
  1. 21.94
  2. 675765.00
0
0
0
0
0
1276
GIG_FULL
96153
123075840
100
961530
195609
1230758400
250379520
  1. 20.34
  2. 765921.00
0
0
0
0
0
1514
GIG_FULL
8127
12336786
10
81270
81270
123367860
123367860
  1. 100.00
  2. 0.00
0
0
0
0
0
1514
GIG_FULL
16254
24673572
20
162540
127721
246735720
193880478
  1. 78.58
  2. 34819.00
0
0
0
0
0
1514
GIG_FULL
24385
37016430
30
243850
243385
370164300
369458430
  1. 99.81
  2. 465.00
0
0
0
0
0
1514
GIG_FULL
32509
49348662
40
325090
199818
493486620
303323724
  1. 61.47
  2. 125272.00
0
0
0
0
0
1514
GIG_FULL
40637
61686966
50
406370
182104
616869660
276433872
  1. 44.81
  2. 224266.00
0
0
0
0
0
1514
GIG_FULL
48770
74032860
60
487700
175060
740328600
265741080
  1. 35.90
  2. 312640.00
0
0
0
0
0
1514
GIG_FULL
56895
86366610
70
568950
158501
863666100
240604518
  1. 27.86
  2. 410449.00
0
0
0
0
0
1514
GIG_FULL
65036
98724648
80
650360
138244
987246480
209854392
  1. 21.26
  2. 512116.00
0
0
0
0
0
1514
GIG_FULL
73185
111094830
90
731850
134749
1110948300
204548982
  1. 18.41
  2. 597101.00
0
0
0
0
0
1514
GIG_FULL
81274
123373932
100
812740
159544
1233739320
242187792
  1. 19.63
  2. 653196.00
0
0
0
0
0
Original Attachment has been moved to: freescale_smartbits.rar
832 次查看
charliechang
Dear Charles,
How to enable the i.mx6 can be tested by Smartbits?
Thank you.
