i.MX6 SPI with 24 bit Transfer doesnt work
1,164 次查看
her
we have the Problem that the i.MX6 SPI dev (Kernel Version 3.0.35) works fine with 8,16,32bit transfers, but not for 24bit.
Is there any update for the i.MX6 SPI driver that fixes this problem?
I have found here a very old patch in the internet, IMX SPI - 17-24 bit bug and >32 bit support. but the code of the i.MX6 SPI driver is quite different
Regards Herbert
941 次查看
alejandrolozan1
Looking at the code I noticed that the ecspi driver supports only a word size of  [4-16] bit.
Can you share the code you are using?
/Alejandro
