i.MX6 DDR3 calibration: How to select System ODT Setting
1,754件の閲覧回数
Wizard_Richard
Dear All,
I am trying to calibrate ddr3 setting for my customer board with 4pcs MT41K128M16JT-125IT.  Firstly, Get ddr3 initial register value by I.MX6DQSDL DDR3 Script Aid V0.10.xlsx, but I don't know how to select "System ODT Setting(ohm)" at the last line of this sheet.
I can get the impedance of DQ/DQM/ADDR/CMD/CTL/CK/DQS from hardware engineer, but how to confirm "System ODT Setting(ohm)"?
By the way, my customer board is based on the SabreSD reference design.
Best Regard,
Richard
ラベル(2)
タグ(2)
2 返答(返信)
1,285件の閲覧回数
Wizard_Richard
May be I can get the impedance of "System ODT Setting(ohm)" from hardware engineer also? am I right?
1,285件の閲覧回数
igorpadykov
Hi Richard
recommended to use settings as in ddr test tool scripts example
(like ddr_stress_tester_vx.y\script\mx6dq\MX6Q_SabreSD_DDR3_1GB_64bit.inc)
i.MX6/7 DDR Stress Test Tool V2.50
some explanations is provided on
https://community.freescale.com/message/601521#comment-601521
