i.MX6 Android BSP cannot mount/unmount a SD card after sleep mode.
3,558 次查看
satoshishimoda
Senior Contributor I
Hi community,
I have a problem about SD card mount issue with Android BSP.
Android BSP cannot unmount and mount a SD card after sleep mode.
Please see the reproducing procedure as below.
[Board]
MCIMX6Q-SDP
[BSP]
android_jb4.2.2_1.0.0-ga or android_jb4.2.2_1.1.0-ga
[Procedure]
1. Boot Android with eMMC boot.
2. Insert a SD card (SD card A).
3. Check the contents in SD card A with ls command. (ls /mnt/extsd)
4. Enter sleep mode by pushing power button.
5. Resume from sleep mode by pushing power button.
6. Remove SD card A.
7. Execute ls command. (ls /mnt/extsd)
8. Insert another SD card (SD card B).
9. Execute ls command. (ls /mnt/extsd)
[Result]
On process 3, I can see the contents in the SD card A correctly.
On process 7, I can see the contents in the SD card A, it is illegal.
On process 9, I can see the contents in the SD card A, and cannot see the one in the SD card B.
[Q]
Could you let me know how should I modify the android BSP to resolve this issue?
Satoshi Shimoda
标签 (3)
标记 (1)
2,986 次查看
PeterChan
Hello Satoshi Shimoda,
To solve this problem, please remove the kernel option "CONFIG_MMC_BLOCK_DEFERRED_RESUME" in arch/arm/configs/imx6X_android_defconfig and rebuild the kernel. This option has a side-effect that prevent the external card to rescan again after system resume.
7 回复数
2,986 次查看
YixingKong
Senior Contributor IV
Satoshi
I will branch this DI into an internal group and assign an engineer to look into.
Yixing
2,986 次查看
xiaoqianlin
I found this issue as well.
After unplugging the SD card, the content is still there.
Linda Lin
2,986 次查看
satoshishimoda
Hi Xiaoqian Lin,
Thank you for reproducing.
Could you check how to modify this issue?
Satoshi Shimoda
2,987 次查看
PeterChan
2,986 次查看
satoshishimoda
Hi Peter Chan,
OK, I will try rebuilding with the setting.
2,986 次查看
satoshishimoda
Hi Peter Chan,
This issue was resolved by your workaround.
Thank you very much for your great support!
Satoshi Shimoda
2,986 次查看
xiaoqianlin
Can you help to assign this issue to AE?
Linda Lin
