i.MX53 SSI Interface with Audio DAC WM8523 - Sampling Rate Issue:
3,127 次查看
GopiNagaBharath
Hi All,
We are using Audio DAC WM8523 from Wolfson in our i.mX53 based custom board.
The Audio DAC is interfaced to to the i.MX53 processor through I2S (Audio Mux) & I2C (Software Control Interface).
The WM8523 driver used is from (provided by Wolfson) : http://opensource.wolfsonmicro.com/cgi-bin/gitweb.cgi?p=linux-2.6-asoc.git;a=blob_plain;f=sound/soc/...
When we use this we are getting an error - "No MCLK configured, call set_sysclk() on init" and the System unable to detect the DAC as the sound device.
Has anyone used WM8523 with any of the i.MX series Processors and were able to get it work?
Gopi
标记 (1)
2,641 次查看
GopiNagaBharath
Yes, i have fixed the issue.
Gopi
2,641 次查看
YixingKong
Senior Contributor IV
GopiNagaBharath
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the
issue, can we close the discussion? If you still need Freescale help, please feel free to contact us.
Yixing
2,642 次查看
GopiNagaBharath
Gopi
2,641 次查看
YixingKong
Thanks, I will close the discussion.
Yixing
