i.MX 8M Plus EVK; NPU example code
1,382 次查看
colinbroderick
I was reading the application note AN12964 PDF, entitled i.MX 8M Plus NPU Warmup Time, and it mentioned some C++ sample code "attached to this application note". However there is no such sample code attached.
Can anyone tell me where to find any C++ NPU sample code. Ideally for running ONNX models on the NPU, but anything you have will be helpful.
1,374 次查看
colinbroderick
Found some sample code but now having trouble compiling it. Can anyone lead to me to any resources on how the include directories should be specified for yocto in general, or specifically an include path for onnxruntime_c_api.h. Should it be specified in CMakeLists, or in the recipe file?
