Flashing yocto build Image using uuu tool
Vivekgv
Hi team,
Dev kit https://www.embeddedartists.com/products/imx8m-quad-developers-kit-v2/
I am using the above dev kit, using Yacto i was able to generate Image files  and is in the path arch/arm64/boot/Image
How do i download the Image to the board using UUU tool ?
Vivek
Vivekgv
Thank you i was able to find the command to load the image from the uuu document
Thank you for the support
joanxie
for the third company party board, you need to consult them, for nxp board, we will offer the script and uuu tool, just use uuu command like, uuu.exe <uuu script> to download images to the board
