i.MX 8M Development kit for AVS Set-up
synatest_tj
Hi, I am trying to build the alexa app with the mrm packages using the User's Guide. After building the app and installing the packages. I can't input the authorization code because I keep getting some messages regarding the mrm package. It keeps refreshing and it does not give me time to input the authorization code. Here is an image of the problem. Also, I am connecting my speakers the way that it's supposed to, but I can't seem to calibrate them.
Any help is appreciated.
Paulina
jimmychan
Have you install the MRM?
synatest_tj
Yes I already installed them.
jimmychan
the next step should be "On your PC, open the browser, go to https://amazon.com/us/code, and register your code.".
