how to play H264+ts file with imx6Q on linux
2,167 次查看
andypeng
Hi all,
  I need to play the .ts file that with H264 Encoder with imx6Q on linux ,how to play?
标签 (2)
标记 (3)
1,751 次查看
imxcommunitysco
Senior Contributor II
Since no reply from you for long time. The DI is assumed answered.
1,751 次查看
weidong_sun
Hello,andypeng,
      In Linux BSP released by freescale for i.mx6q, gstreamer is used to play video. you can compile it by LTIB ,  at the same time , ubuntu system supports i.mx6 platform , So you can aslo run ubuntu system on your board based on i.mx6. In ubuntu root file system, gstreamer has been supported. you can use it to play video.
Weidong
1,751 次查看
LeonardoSandova
Specialist I
Once you have the system ready, you can type one of these commands:
$ gplay yourfile.ts
$ gst-launch playbin2 uri=file://`pwd`/yourfile.ts
