IMX6Q can not start up with prebuilt image in android_jb4.2.2_1.1.0-ga_image_6qsabresd
已解决
跳至解决方案
3,396 次查看
jojorong
     I use the prebuilt image in "android_jb4.2.2_1.1.0-ga_image_6qsabresd",
     i configure the boot command is:
U-Boot > setenv bootcmd booti mmc2
U-Boot > setenv bootargs console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M
init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb1:off video=mxcfb2:off
fbmem=28M androidboot.hardware=freescale
but there are some error like following, the board can not start up :smileysad: :
root@android:/ # request_suspend_state: wakeup (0->0) at 1932920403232 (1970-01-02 00:32:01.088688896 UTC)
init: untracked pid 32142 exited
init: untracked pid 32141 exited
ERROR: v4l2 capture: slave not found!
binder: 32360: binder_alloc_buf, no vma
binder: 32397:32397 transaction failed 29201, size 92-0
request_suspend_state: wakeup (0->0) at 1950190331234 (1970-01-02 00:32:18.358616565 UTC)
init: untracked pid 32398 exited
init: untracked pid 32397 exited
request_suspend_state: wakeup (0->0) at 1966310999569 (1970-01-02 00:32:34.479284233 UTC)
init: untracked pid 32652 exited
init: untracked pid 32650 exited
request_suspend_state: wakeup (0->0) at 1982610409237 (1970-01-02 00:32:50.778694902 UTC)
init: untracked pid 443 exited
标签 (2)
1 解答
2,618 次查看
jojorong
When i re-burn the prebuilt image of this version with MFTtools, it's ok :smileyhappy:
在原帖中查看解决方案
4 回复数
2,618 次查看
liyu1
你好!
         这是freescale的bug之一,我这边得到了解决,当插上鼠标等这样的输入设备时系统就会起不来。你需要把鼠标等输入设备拔下才能进入系统,系统报错的地方是找不到mma8451等传感器设备,才在那里一直找。
2,618 次查看
brajeshsharma
Hey ,
I am struggling with the same problem as you did , i have used prebuilt images for sabresd OF ANDROID JELLY BEAN 4.2.2 and board is booting up but there is no display on HDMI monitor and console keep giving me errors like :
You sorted this out usiong MFGTool , i am asking is there any solution by using SD-Card itself .
Any help would be appreciated .
Thanks & Regards
Brajesh
2,619 次查看
jojorong
2,618 次查看
jojorong
Nobody use IMX6Q with Android ???
