how to open imx6dl clk
1,094 次查看
tony-tony
I want to open CSI clock in imx6dl board, find it is different from imx6ul, how to configure and enable it ?   check the " clk-imx6q.c" file , and find it have not configure the CSI clock( not sure).
标签 (2)
标记 (1)
1,026 次查看
Hi tony
first please enable csi, refer to imx6ul-14x14-evk-csi.dts :
http://git.freescale.com/git/cgit.cgi/imx/linux-imx.git/tree/arch/arm/boot/dts/imx6ul-14x14-evk-csi....
Clocks are configured using linux common clock framework which is described in
https://www.kernel.org/doc/Documentation/clk.txt
http://elinux.org/images/b/b8/Elc2013_Clement.pdf
