I'm developping some embeded board with i.MX8mq
I want to know how to apply it.
If you have a patch, please let me know.
thank you.
Solved! Go to Solution.
 diegoadrian
			diegoadrian
Probably it could be possible, but I cannot guarantee anything. I can see that the dts from u-boot, has support for the MIPI-DSI. However, the only driver that I could find is for HDMI. Probably you will need to add the MIPI driver to u-boot. Unfortunately, I can not tell you if this the only thing that you need. This is as far as I can go. I apologize for the inconveniences this could give you.
Diego.
 diegoadrian
			diegoadrian
Diego.
Hi diego.
Thank you for your reply.
