how to default use a72 instead of a53 with imx8qm
4,928 次查看
jiangyaqiang
HI :
       Currecntly, when boot up MEK board of imx8qm, the default cpu cpu0 is a53, does there any way to change to a72 ?
4,828 次查看
zhao_yang
OK, The following picture  is the detail information about the doc.
I also add the  attachments here.
7 回复数
4,828 次查看
zhao_yang
hi,Yaqiang
Here is an example to change the primary CPU as A72. I hope this can give you some help.
https://community.nxp.com/docs/DOC-347300
4,828 次查看
jiangyaqiang
HI Zhao:
Thanks, but I can't access the link:
4,829 次查看
zhao_yang
3,221 次查看
aroffelsen
What are these patches supposed to be applied to?
4,758 次查看
传策薛
I use the Android9.0
4,764 次查看
传策薛
Hi, how to patch "A53-to-A72-trusty-001.patch"
4,828 次查看
lily_zhang
zhaoyang-b49593‌, please help on it.
