hi commuity
on my custom board i like to use CLKO1 as a referece clk of a slave device
i searched commuity and i found it can be done in devicetree with assigned-clock
but i don't find clk names
i set SD1_CD_B pin as CLKO1 output in devicetree
what clock should i use to configure CLKO1 to ouput 24MHZ
thank you sincerely
